Results 1 to 10 of 11
July 25th, 2011 08:47 PM #1
I have a Kia Besta model 98 with a 2.2 Liter diesel engine. I think one of the cylinders is bad already and which might necessitate an overhaul. Can you please let me know of any reputable engine overhauling center in the Las Pinas area. Many Thanks
July 25th, 2011 11:44 PM #2
Diesel Calibration, Diesel Fuel Injection Pump Calibration, Diesel Turbo, Diesel Overhauli - Parañaque - Repair
PM Dieseldude as he might have a few contacts there.Fasten your seatbelt! Or else... Driven To Thrill!
August 2nd, 2011 10:03 PM #3
I had my injector pumps calibrated..that helped. I also had the engine compression tested and the results are #1-15, #2-16, #3-17 and #4-17. I was told this is really below par as diesel engines need to be 20 to 22. Any comments? Does this mean my engine has lost compression already?
- Apr 2011
- 78
August 2nd, 2011 10:49 PM #4
August 3rd, 2011 05:47 PM #6
Thanks, yes. I checked my last oil change and I'm still using 15w-40. What does it mean if if I use 15w-50? What brand do you recommend?
Tsikot Member Rank 3
- Oct 2006
- 1,069
August 3rd, 2011 06:45 PM #8
August 4th, 2011 12:59 AM #9
Thanks for all the comments ... will do an oil change this weekend. Hope it works!!! :-)
August 4th, 2011 12:49 PM #10
Follow manufacturer's oil specs sir.....try using monogrades for looser engines. if it still eats up the oil then start saving money.
