Results 21 to 26 of 26
November 19th, 2007 12:50 PM #22
I prefer doing it cold in the morning before starting it. Your engine is .040mm hot or cold so its up to you. Messy kasi pag nagcirculate na yung oil at mainit yung valve cover and other components.
- May 2004
- 903
November 22nd, 2007 02:24 PM #23
November 25th, 2007 01:03 AM #24
How about the white smoke? All day ba na may white smoke or during cold starts lang? If the white smoke symptom persists, you may need to have the valve seals replaced.
November 25th, 2007 09:16 AM #25
If i remember it correctly, kahit hot na meron pa ring white smoke. For your ease of mind, the best option is to have a compression test. It's cheaper than overhaul kaagad.
- May 2004
- 903
November 25th, 2007 09:50 PM #26
Traffic!
