mga pips ...ano ba reason pag arangkada ko ay may tumutupe or parang nabibila ukan ang REVO GL na gas..at ano solusyon gagawin ko ..naka ilang balaik na din sa casa di nila maalis..
.thanks in advance
these are general things you need to check, not necessarily for the revo but for all gas engines suffering from loss of power:
incorrectly set ignition timing
faulty high tension wires
fouled spark plugs
faulty ground wires/corroded ground wire connections
loose connection in the ignition system, especially on the ignition coil and ic
plugged fuel filter
plugged fuel strainer in the gas tank
faulty fuel pump
water in fuel
plugged carburator jets for carb engines/plugged fuel injectors for efi engines
faulty ecu for efi engines (nakow patay kang bata ka!)
clogged air filters
fully open egr valve resulting to too lean air/fuel ratio (see below)
too lean a/f ratio (symptom = higher engine temp than usual, engine knock)
too rich a/f ratio (cold engine, smoke)
timing gears/chains/belts out of sync/incorrectly installed
misaligned clutch pressure plate
torn engine and transmission mounts resulting to too high torque on engine
dami pa. kaya hirap sila makita sira nyan kasi dami pwede causes eh.
