Results 51 to 60 of 74
February 15th, 2015 11:56 PM #51
at the parking lot earlier mga 3 minutes na nasa 1/4 palang, umalis nako kasi sama pakiramdam ko. ang tagal naman pala mag intay
February 16th, 2015 12:13 AM #52
Gasoline fed po ba ang sasakyan nyo Sir ninjababez?!
Kung 3mins for gasoline fed vehicle, ok na po yan, safe na at kahit hindi paabutin sa normal range, pwede na itakbo dahil mas madali mag-warm up ang gasoline, unlike sa diesel, mas mahabang pasensya ang kailangan, kung confined area, iwasan po na mag stay sa area lalo sa rear area, dahil sa carbon monoxide, safe distance enough para i-monitor ang sasakyan, both security and safety.
As much as possible, kung confined area, hanap po kayo ng area na merong ventilation, at mataas na area dapat, kung sa basement parking naman, lagpas lang sa C area, then drive smoothly, mas matindi ang emission at inhalation ng carbon monoxide dahil kulob ang area
February 16th, 2015 11:21 AM #53
RE: Warm-up:
http://www.topgear.com.ph/features/t...robably-making
Three minutes is too long. Get in. Start the car. Buckle up, adjust the mirrors, set the radio... the car is warm. Oil has now circulated up to the valvetrain and it's safe to go out.
Drive it out of the parking lot. Keep revs low until the temp gauge gets to 1/4th, then give it a little more. Then wait until you're up to operating temperature to use full revs.
Warming up in the parking lot takes a loooong time because the car isn't doing anything to warm itself up. It's like preparing for a basketball game by standing on the sidelines breathing heavily. Your engine is getting warm, but your gearbox oil, differential oil (on RWD cars) and brakes are still ice-cold.
Since the temperature gauge has no units, it's not as useful as old-school gauges that will give you approximate temperature.
But typically, middle or just below middle is normal.
I'm still sad that new cars don't have oil pressure gauges. Those were very useful.
February 16th, 2015 01:25 PM #54
binago ko na ritual ko sa starting from 3 minutes to just less 1 minute before moving the vehicle. yung oil pressure light and gage ang tinitignan ko as well as the vibration ng makina. kapag nagoff na yung pressure light tapos nagregister na sa pressure gage, i wait for the vibrations to settle down. then go. for the whole duration of the "ritual", hindi ko nirerebolusyon ang makina since turbodiesel sya.
i agree na mahalaga ang oil pressure gages. aside from the tach and speedo/odo, ang 3 gage na sa tingin ko present "dapat" sa isang sasakyan ay coolant temp, oil pressure, voltage and fuel level. mas maganda pa nga kung may oil temp at exhaust temp pero sobra na iyon kung daily driver lang naman. but i would prefer to have them. provided alam ng driver maginterpret ng readings (setting aside yung fuel level syempre).
si erpats sinasabihan ko lagi nun na wag irebolusyon ang makina ng truck nya once na magstart. ayun, mahirap pasunurin. ....kung tutuusin sya pa nga nagsabi sakin nung newbie pako na hayaan mo munang umikot ang langis sa makina.
isa pa, sasabihin pa nya palagi na nagooverheat na truck nya. pagtingin ko sa gage, nasa 170 F naman. normal iyan kako, yung pickup ko nga 180 F (82 C) pa nga e. old habits talaga.
ok, back to topic.
- Apr 2012
- 3,469
February 16th, 2015 01:48 PM #55Sa Vios ko pag nawala na yung blue light ng temperature i go na. Pero alalay na takbo lang di hataw since medyo slow moving mga sasakyan pag labas sa main road namin.
Sa Grand Starex ko naman after a minute go na ako. Pero alalay lang until it reaches the normal operating temparature
- 52,517
February 16th, 2015 01:49 PM #56i just wait for the oil indicator lamp to turn off, then i roll.
fortunately, my neighborhood does not allow for rapid car movement.. this allows the oil to circulate thruout the engine, before i can put in faster speed..
yes, i do miss all them dials, but today's cars have only idiot lights..
if your dad has driven that truck of his for 10 years and it hasn't broken down yet, bat ka naman paniniwalaan..? ... young know-it-all... heh heh.
February 16th, 2015 02:07 PM #57
kaya nga i rest my case na lang ang sagot sa kanya....tsaka isa pa e not regularly used yung truck nya. who knows kapag nadistrongka na for repair dun na magsilabasan ang mga issue due to starting habits.
February 17th, 2015 12:00 PM #58
The oil pressure idiot light, actually, is all you need to look at to know whether it's safe to move, already... but the temperature idiot light and gauge are what tell you if it's safe to rev.
My perfect car would have only oil pressure, water temps, voltage, rpm and fuel on the primary cluster. Then I'd have a secondary display gauge for exhaust gas temps and wideband O2 sensor readings, right beside a mixture "lean" and "rich" dial.
May 12th, 2015 08:23 PM #59
Up ko lang. Attached is an interesting reference for trouble shooting diesel turbo problems
Garrett Turbocharger Troubleshooting Guide | Turbobygarrett
- Jan 2014
- 54
December 30th, 2016 11:14 PM #60Question po. I'm planning to buy 2nd hand na Ford Focus 2007 2.0 diesel. When I asked a mechanic, he said na iwas sa diesel cars kasi not good ang cooling system because maliit yung engine area so not much air and di elevated unlike pick-up and SUV. Additionally, city driving with bad traffic condition yung location ko. Pag umuwi ako ng gabi, 15 mins travel lang from office to house. Pag house to office during daytime, 30-40 mins tapos 2nd to 3rd gear lagi. Di ba advisable yung diesel hatch if ganito?
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
