Results 11 to 18 of 18
- Mar 2006
- 39
January 21st, 2009 10:20 AM #11oil leak from turbo may come out from exhaust side of the turbo or from compressor side. if it comes out from compressor side, it is then pushed into intake manifold burning the oil in the process, thus causing the blue-to-black smoke. same effect if your oil makes its way thru piston ring which burns the oil together with fuel and air.
as i have mentioned, air filter was removed, hence, air filter factor negative. no oil splatter when oil filler cap and oil dipstick, hence, no 1st level sign which suggests losing compression. before calibration+nozzle replacements, all other factors must be taken out from the equation first as much as possible to give more warrant on getting into calibration+nozzle replacements. carbon buildup taken out by cleaning exhause pipes + oil buildup through the turbo pipelines going into intake manifold.
anyways, turbo is A-okay, nozzles are A-okay. As of now, no unsightly blue-to-black smoke coming out even at 4k RPM.
rion, where did you get those oil-catch tank pics? are they available locally? i made DIY oil-catch tank myself, of course, not quite close to those pics aesthetically =D
thanks.
January 23rd, 2009 02:44 AM #12
they are DIY, not mine though. mine looks crap.
there are oil catch can available localy but too pricey...
- Mar 2009
- 1
October 13th, 2009 02:46 PM #13mga sir.. i have this nissan turbo patrol 91 model.. pag nag start cya nag cho choke pag nka idle at malamig pa makina.. maitim din usok... may idea kayo kung magkno ang pa calibrate??
- Mar 2010
- 1
March 19th, 2010 03:39 PM #15me problem ang kia carnival na nabili ko model 2002 galing ng korea crdi 145 high power direct injection. ung #4 na wire papunta sa nozzle tip nya ay nasunog pinalitan namin kaso mahina syang umarangkada at maitim
ang usok..kailangan po bang linisin nozzle nya electronic po sya
- Sep 2006
- 1,335
March 19th, 2010 07:00 PM #16Last edited by Dieseldude; March 19th, 2010 at 07:04 PM. Reason: improve message content
- Apr 2010
- 57
January 18th, 2014 04:00 PM #17Mga Sir, ask ko lang wala na po kasi ang Betan sa P. Ocampo street, Makati. Read somewhere lumipat na daw ito sa Delpan street, Manila? Anyone knows the new location and contact number? Hindi po kasi updated yung nasa website nila. TIA
- Nov 2003
- 58
February 18th, 2014 11:40 AM #18^^ Same question. Does anyone have the tel. no. of Betan? would appreciate if someone can post the new address and contact number. Thanks
Suzuki JIMNY [merged threads]
