Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 71 to 80 of 99
    Feb 2015
    #71
    Quote Originally Posted by kkreuk18 View Post
    Pagdating sa oil filter mukhang satisfied naman ako sa js asakashi. Ang claim ng company ay pede gamitin gang 15,000 km.
    Sent from my Redmi Note 5 using Tapatalk
    Sir magkano kuha mo sa js asakashi oil filter?
    P350 ang bigay sakin.
    Nagtataka lang ako na mas mura pa siya sa vic.
    Baka lang peke yung binebenta sakin.
    Jan 2008
    #72
    Quote Originally Posted by makelovenotwar View Post
    Ganyan din. Same price ng pagkabili ko sa vic nun huli. Dati 280 ko lang nakukuha un vic tapos tumaas
    Jan 2008
    #73
    Naghahanap ako ngayon ng nagbbenta ng delo 400mgx 18L na malapit sa area ko. Para mas mura.
    May 2017
    #74
    I switched to Delo 400 MGX for my 2016 Dmax since I got 35k.
    Now 56k and engine running very good.
    The new Delo 400 is as good as some semi synthetic oils. It's very good for egr and DPF fitted diesols.
    You won't get sludge provided you change oil regular and hardly any carbon build up as this oil has great protective and cleaning additives. And it can handle the heat better than most other mineral oils.
    But I always change oil at around 5k regardless because even if your using 100% synthetic oil the dirt is still their circling around inside your engine,. I dont like long oil changes that's why I use mineral oil so I get the dirt out sooner.
    Yes you can get 10k from fully synthetic oils but the longer the oil stays in the more dirt you will have inside your engine curcling around. And even though fully synthetic oil take longer to break down than mineral oil you still have suspended dirt flowing inside your engine longer.
    For modern SUV and pick ups in the Philippines you can't go wrong with Delo 400 MGX As long as your vehicles Manuel says it's ok to use 15w-40 weight.
    My manuel says Delo 400 is ok to use so I use it
    I don't use a catch can or block the egr as many others have done.
    Bottom line is if you want your diesol to last then remember the 3 basics
    1 clean oil...regular service.
    2 clean fuel.....fuel filter replace every 10k even if you have a pre filter.
    3 clean air.......I clean air filter every 5k and replace every 20k.
    God Bless You
    #75
    Oo, pwede mga P15 less per liter yan if ganyan kalaki packaging. Sulit sa fleet owners or may 2 diesel cars at least.
    #76
    how much na ngayon ang liter ng mgx? hindi ko alam kung mas mura sa lazada or sa caltex stations pa rin ang better deal
    hassle na ang delivery ng lazada din kasi
    Jan 2008
    #77
    Hanap ka na lang ng shop na merong mgx. Mga 230-260 pesos ang range ng 1L, sa caltex station 300+
    #78
    kanina pa nga ako nagtatawag sa mga auto parts store sa las pinas pero hindi sila nagbebenta eh.
    Jan 2008
    #79
    Parang mas mura pa sa lazada.. tsaka wala halos stock yan mgx sa gas station.. bulok kasi mga caltex station
    Jan 2008
    #80
    A las piñas area ka pala. Un kinukunan ko kasi super miler imus, cavite. Un other branches nila, cubao at valenzuela
Delo MGX 80,000km OCI
