Results 11 to 20 of 20
- Feb 2005
- 99
June 17th, 2005 04:01 PM #11Diesel ba van mo? Baka kinakabagan lang meaning may hangin sa fuel line. You can try i-bleed fuel line mo thru the injector para mawala hangin.
- Feb 2005
- 99
June 17th, 2005 04:51 PM #13I see. Possible that you have to change your fuel filters. You can also try to have your carburetor cleaned or serviced baka kasi nagbara sa loob.
June 19th, 2005 12:59 PM #14
in my case, nagpalit lng ako ng fuel filter den back to normal na. :D
- Sep 2004
- 15
June 19th, 2005 01:44 PM #16check your air filter, ignition timing, tire pressure, spark plugs & wires. also your carburetor might be running rich or has worn jets.
- Jun 2005
- 25
June 19th, 2005 04:07 PM #17I suggest you try the accetone trick. Same din kasi tayo ng problem before & the accetone did the trick & the good thing is halos wala akong nagastos.
SiRaNeko
- Jan 2003
- 973
June 19th, 2005 09:53 PM #18kung plastic lang fuel filter mo, di ba mura lang yon?
i believe wala pa 500p? so mura lang magpalit
June 20th, 2005 10:45 AM #19
ok na mga bro! pina-vacuum ko lang yung fuel filter.
Yung mabigat na takbo nya, the mechanic told me about the angle of the contact point. Ano po dapat adjustment for Vanette?
SiRaNeko
- Jan 2003
- 973
