Results 1 to 5 of 5
    Apr 2005
    good day tech gurus,
    need your usual help on my innova unit d4d a/t.problem listed below
    1.check engine light - new computer box & instrument cluster
    2.airbag light
    3.automatic trans doesnt shift from high gear to low gear
    its hard to accelerate from stop if its on drive gear(D),but when it runs
    already at 20-30 kph D gear can goes up to 100+ kph.no problem on L gear
    ( change 3x atf with opening of oil pan,clean filter)
    FYI. unit was stored from flood
    TIA
    Aug 2004
    Quote Originally Posted by nitram View Post
    2.airbag light
    TIA
    Electronics, electronics, electronics. Even if you've replaced the ECU after a flood, many of the elctronic parts may have been damaged or compromised by the flood.
    How long was it stored? This could have given trapped moisture time to corrode wiring or connections. You shouldn't store a flooded vehicle unless you've taken it apart and had everything completely dried out.
    Best to have a dealership or a shop read the CEL code so you know which engine sensor is busted. If the airbag light is lit, even with a brand new ECU and cluster, then your airbag or airbag sensors have problems.
    The automatic, sounds like a solenoid problem. Doesn't sound crunchy, does it?
    The shops that can only deal with this kinds of troubles are those who are fullly equipped with scan tools ,technical info and competent auto techs .
    It can be dealt in a case to case basis . Once its underwater , its gonna be very difficult to fix it one shot.
    Make sure to have the list of what has been done after the flooding in order for the next tech to view the history.its gonna be very costly.
    Apr 2005
    fyi .
    it was stored for 2 months - electricals was taken out during that time
    aside from ecu & instrument cluster,we also replace injector drive & 1 injector.
    units runs already for a month(with check engine light&airbag)
    for the a/t - no sign of crunchy sound,its whistling sound when accelerate.
    thanks
    Feb 2010
    Hi,
    Our Innova is encountering the same problem - - from what I understand, the ECT is broken (it's a box located beside the ECU that controls the transmission), therefore there isn't any automatic shifting functionality. When you shift to D, it actually engages third gear.
    While waiting for a replacement ECT I still use our Innova - - I use L, 2 and D to shift from first, second and third gears respectively.
d4d check engine/trans problem
