Results 61 to 70 of 78
April 11th, 2017 08:02 PM #61
Ask sana mga bos ng updated price ng palit ng 4d56T Timing Belt ng Spacegear local 2003, may ugong na tunog kasi posible daw sa tensioner nanggaling.
Magkano kaya abutin,
Timing Belt
Tensioner
Labor
Misc parts
San ang recommended shop to do this around Banawe Area or Manila Area...
Salamat.
Sent from my SM-G935W8 using Tapatalk
- Apr 2017
- 1
May 3rd, 2017 10:31 PM #62Need Help just inherited my dad's '98 Fieldmaster and found out that he has not changed the timing belt yet * 100,000++ on the odometer. What parts should I be replacing aside from the belt itself and the water pump (I believe) and how much will everything cost at this time? TIA
- May 2011
- 481
May 4th, 2017 07:22 AM #63Change all MAW (might as well) parts to include crank oil seal, camshaft oil seal, all idler pulley, all tensioner pulley and of course the timing belt. All of these parts were installed on the same hour on the same day which means they all have the same mileage and the same number of hours of run time.
- Sep 2006
- 1,335
May 5th, 2017 05:11 PM #64
May 12th, 2017 01:02 PM #65
Inaayos ko at the moment yung pickup ng pinsan ko.etong sasakyan na yung nafeature dito sa thread.
Naputulan ng balancer belt tapos nabungi yung cam belt dahil nasabawan ng engine oil dahil sa tumatagas na oil seal. Tapos pinilit pang paandarin.ouch!
Ayun nabasag ang apat na rocker arm at 2 bearing cap ng camshaft.....
Yung less than P3k na gastos lang sana sa timing belt replacemeng naging P8k...
May 12th, 2017 01:48 PM #66
^ ilan na ang tinakbo niyang pickup na iyan bos?
May 14th, 2017 10:47 PM #67
diko na alam kung ilan kilometers na pero last march 2014 ang huli kong palit bago ko binenta kay pinsan....tingin ko e less than 30k km pa lang.
pinambuhat ng mga construction materials para sa bahay nya, pandeliver ng baboy at baka, kung saan saan birhaws napunta (hehehe),....utility work.
diko na tinanggal cylinder head para inspect ko sana valves...napagana ko naman na ulit....so far wala naman abnormal noise at white smoke. natsambahan. nakakatamad ding gumalaw kasi ngayon dahil sa init.
May 20th, 2017 08:50 PM #68
May 23rd, 2017 02:27 PM #69
dalawa kasi ang engine model ng 4D56. pre-1994 at post 1994 models...nagkaiba sila sa cross section ng t-belt at haba ng balancer belt (old has 83 teeth sa balancer while the newer have 99 teeth)...tapos "rectangular" teeth ng old models while "round" naman yung profile ng t-belt ng new models
price of the old model t-belt (bando):
cam = P750
balancer = P450
kung plus labor around P3k....hindi pa kasali ang oil seals, tensioner bearings, etc.
bale nagastos kasi netong huli aside from the t-belt ay ang sumusunod:
intake rocker arms (4 pcs) = P 1,100
Camshaft bearing caps/holders = P 1,980
gaskets, sealants, oil seals (mura lang naman mga ito), oil, hoses, clamps na mamahalin, gasoline, etc......
hindi ko na pinalitan ang tensioner bearings. grinasahan ko na lang uli mga ito. selyado yung bearings pero actually nasisikwat yung cover nya. be careful nga lang para hindi masira yung cover.
- Sep 2016
- 72
June 8th, 2017 05:13 PM #70naranasan ko ng maputulan ng timing belt. dami kasi mekaniko na "OK PA YAN" pag nagtanong ako kung ok pa ba kahit di na. nagdridrive ako 12 ng gabi sa isa pang masukal na lugar walang kabahay bahay na highway. tinatakbo ko e 100kph at bigla nalang may tumunog na naputol na belt. namatay agad engine tapos mga ilaw. sinubukan ko pang sstart ng 3 beses pero ayaw talaga. kaya iniwan ko nalang sa gilid ng kalsada at 2 hours pa akong naghintay ng bus nalang ako umuwi. nung binalikan ko kasama mekaniko at binuksan ung cover. naputol 3 rocker arms, gasgas ung camshaft at ung sa upuan nung camshaft as in nadikit talaga ung camshaft dun sa cylinder head. Isang masakit na karanasan ang maputulan ng T belt lalo na malayo ka at gabi pa. huhu
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
