Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 78
    #31
    Thanks for this very informative article!
    Nov 2015
    #32
    Thanks for this article. Thought I would just add to it what I discovered today. I have had an oil leak in the front crank seal on and off for quite a while. The last time I re-sealed it I thought I had it sorted until about 6 months ago it started leaking worse than ever. Finally I got time to get a new seal and tear it down. Initially I was confused as the seal was in perfect condition and it was in place and stable. While extracting the old seal I noticed the oil pump drive sleeve seemed quite loose and I was curious as to if there was a defect in the surface the seal seats on. I extracted it and looked it over to no avail. While there was quite a shiny patch where the seal had been running there was nothing else obvious that might cause an issue. I showed my son the part and he said there is a crack in it and sure enough when you got the light right and pulled the sides apart a hairline crack in line with the key way is obvious. I since found this is not unheard of and often the cause of oil leaks that won't stop so I thought I would share it here in the hope it will help others. A couple of images to show the crack.pb120320.jpg
    Aug 2011
    #33
    Thanks for this very informative thread. Question, lang po, is it the same procedure for replacing the timing belt of second gen strada 4x4 4d56 engine? Tia
    May 2009
    #34
    Quote Originally Posted by Tj_abs View Post
    yes sir. virtually the same.....iba lang siguro ang teeth count ng balancer belt (83 or 99 teeth). atsaka teeth profile (rectangular or round) sa t-belts.
    Mar 2015
    #35
    thanks po dito. same din po eto sa mitsu adventure 08 diba?
    Jan 2016
    #36
    Naputulan po ako ng timing belt, what do I expect sa unit ko (Montero 2010 model), currently, nasa CASA for estimate...thanks po...
    May 2009
    #37
    Quote Originally Posted by bfi1234 View Post
    bukod sa timing belt na papalitan e ipanalangin nyo po na valve lang ang may tama or tappet (kung meron man iyan). worst case scenario e dented pistons, bent or broken connecting rod, bent or broken crankshaft (brand new engine na katapat ng mga ito or overhaul).
    hmmmm...2010. usually 6 years tinatagal ng rubber so i assume hindi pa napalitan iyan since 2010 (tama ba ako?).
    May 2009
    #38
    Quote Originally Posted by hitokiri1 View Post
    yes. basta yung diesel yang adventure po ninyo.
    again, sa teeth profile at balancer belt teeth count nagkaiba. newer models ng conventional 4d56 ay semi circular na ang teeth profile at 99 teeth ang balance belt, kung tama ang aking alaala.
    #39
    ano milage ng car? high revving ba parati?
    Jan 2016
    #40
    Quote Originally Posted by miked View Post
    Sana nga po ma save pa ang engine, never pa akong nagpalit ng timing belt, mileage ng unit ko is 79K KM, parang feeling ko masyado mabilis na damage base sa experience ko with my other cars na mas matagal kong nagamit, thanks.
Crash Course on 4D56 Timing Belt  Replacement (with Pics)
