Results 1 to 10 of 78
January 27th, 2012 10:11 AM #1
This write-up is for informational purposes only....
First is to remove the radiator (& hoses) to give you enough space. Disconnect also the lines connecting the transmission cooler (for automatics). Remove all V-belts (A/C, PS, Alt), A/C tensioner.
Remove the Crankshaft pulley damper using 2 techniques. If you are man enough (not like me), do this one:
wrap a chain wrench on the pulley then use a breaker handle with socket (19mm on these engines). you may need an assistant for this to hold the one wrench
or if you are alone, do this trick: ground the breaker handle to the vehicle frame then one very short burst of the starting motor. voila! crankshaft bolt loosened!:
Remove the crank bolt and the damper pulley. aside from giving power to engine auxiliary systems (A/C, ALT, PS), the crank pulley also serve as a vibration damper. it absorbs and smoothens the power pulses from the engine. Replacement crank pulleys usually costs about P3k (with the key)
rear view of crank pulley
front view of crank pulley
January 27th, 2012 10:18 AM #2
Here is the crank bolt which is a high tensile bolt (grade 10 and some are grade 7 marks on the head). bolt is M14 x 1.5 iirc.
Upon removal of the bolt, pulley and lower timing cover, thread back the crank bolt...
and align the timing marks on the camshaft
fuel injection pum
crankshaft and lower (right) balancer
and upper (left) balancer shafts
January 27th, 2012 10:35 AM #3
Word of Caution: Always rotate the timing assembly via the power source which is the crankshaft bolt (not on the injection pump or camshaft) or else you'll screw up the timing....some engines also rotate counterclockwise but for this application it rotates clockwise facing the engine.
before removing the cam belt, take the bolt out. the timing may move back so hold it via the fuel injection pump.
To remove the cam belt, remove it following the instructions from the manual sourced from the internet:
that is, loosen the NUT first on the upper tensioner bearing then the bolt on the slot side. Then pry the tensioner using a screwdriver towards the water pump and hold it there by tightening the slot side bolt then nut
Upon removal of the cam belt, follow again the manual by loosening first the lower tensioner bearing's nut and bolt.
Upon removal of the belts, remove the 2 crankshaft sprockets (1 for the cam, 1 for the balancer). the key will also come off. don't forget the key. take note also the direction of installation of the flange. failure to install the flange correctly will snap the belt.
January 27th, 2012 10:43 AM #4
You may have noticed, the timing assembly was bathing in oil. the problem was a front crank oil seal ready to jump out of its seat. once the belts are soaked in oil, replace them asap.
the outer diameter of the crankshaft is about 43.95mm...that would be the internal diameter of the oil seal. hope the oil seal will take care of the 0.05 difference. btw, the oil seal size for this one is 44 x 60 x 7 mm.
To remove the seal, pry it out with a screwdriver (with a cloth to prevent marring the shaft or the housing).
Clean first the front assembly
January 30th, 2012 11:47 AM #5
I cut and used a spent refrigerant drier filter to push the new oil seal in the housing.
For the reassembly, i have to be cruel. Reassembly is the reverse of diassembly.
Just don't forget to torque every bolt to specs especially the crank bolt (130 ftlbs).
Check the timing by rotating the timing assembly twice or thrice (via the crank bolt) before firing up the engine.
Hope this helps especially to the newbie on this type of DIY.
January 30th, 2012 10:53 PM #6
Sticky! For Reference Purposes
January 31st, 2012 08:43 AM #7
add ko lang-- turo sa akin ng mekaniko ko while we chage the t.belt of my former delica:
set mo muna ang timing to 1 (may markers yun) bago alisin ang belt.
January 31st, 2012 11:31 AM #8
- Dec 2009
- 304
February 16th, 2013 11:37 AM #9Sir Miked, timimg belt ba or timing chain nakakabit sa 4M40 na engine? Thanks
February 16th, 2013 11:50 AM #10
Gears and a chain as per the manual from the net.....http://www.mitsubishi-motors.kiev.ua...ee9409/11A.pdf
Suzuki JIMNY [merged threads]
