Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    #21
    thanks bambino ... i am not a serious mechanic, just a car enthusiast with engineering background ... i only troubleshoot our own cars ... its enough that you introduced the technique of checking compression problems electronically ... with my crude tools, i can do it barok way
    it looks like your future gadgets would include pressure transducers so you can finally have true pressure waveforms
    #22
    Wow im so interested sir bambino for a newbie like me...
    #23
    Quote Originally Posted by AzRieL21 View Post
    if you are serious of fixing cars , upgrading your skills is the best investment
    are you interested of some tools that you can build yourself ?
    or the picoscope kit with first look sensor kit ( pressure transducer )
    Apr 2008
    #24
    Speedlab 2k compression test for diesel
    #25
    mahal pala compression test diesel. nagtanong din ako kay speedyfix petrol/gas lang cla compression test.
    #26
    Quote Originally Posted by bambino View Post
    i read that you work with diesels and this machine is perfect for it
    you have'nt seen the misfire diagnostics capability of this amazing tool and the test will only take 5 minutes or less
    considering the precise mechanical diagnostics
    Dalawin mo kami when you are in the Philippines. Medyo hirap lang negosyo but we would like to know breakthrough in our line of business.
    Apr 2008
    #27
    correction. hindi pala sa speedlab na inquire ko for the diesel compression test na 2k. sa autotechnika pala sa the fort yun.
    #28
    *bambino
    How do i disable ignition on our Starex for compression test? It is model 2003 TDCI engine. I hope it is as easy as for a gas engine.
    Thanks.
    Sep 2006
    #29
    Quote Originally Posted by kinyo View Post
    *bambino
    Thanks.
    If your fuel injection pump is the VE (ROTARY) type, you will have to disconnect the wire to the injection pump's shut-off valve so that the pump will not deliver fuel to the injectors.
    If it's the later common rail system, the fuse to the ECU should be removed to prevent the ECU from triggering the injectors.
    In both cases, you are preventing the engine from running by electrically disabling the injection system.
    #30
    *bambino
    Thanks.
    ignition key off , use a remote starter switch to crank the engine
    that way you're not inviting the check engine light to set on you
    but the best if you are properly equipped to handle a diesel one
    #31
    Thanks Dieseldude and bambino for your inputs ... now i know it is not as easy as for gas engine
    I haven't had a close look on the engine ... but i was thinking of detaching electrical connectors on all injectors if accessible ... would this work too? without bad effects?
    Thanks again.
Compression Test Question
