Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
    #41
    as mentioned people are asking what will happen after five years to CRDi engines.. well the first CRDi hilux i saw in thailand was in 2002,, they had it then already,, last june i was there and i had a frend who had a hilux older version not the new ones and its still running well....so what then is realy the problem on some current models of CRDis here? the first thing people tend to say is the fuel is dirty.. but not everyone is having the same problems.. just curious..
    Jun 2007
    #42
    i think the crdi system on the hilux and fort 2.5 d4d has been detuned to compensate for the dirty diesel fuel that has been distributed by some of our fuel providers,my friend also has some problems with his engine and what he did was installed an ecu upgrade or crdi tuning module after that his problem with his crdi is gone,the only problem i think is the knowledge and technical know how of some mechanics or even in the casa is still learning stages,as what we used to have before when the first efi engnines came to the market,but as years progress some even backyard mechanics can tune the efi system.. i like the crdi systems coz it can be tuned with simple crdi tuning upgrade and can produce more horsepower and torque.
    Jun 2008
    #43
    Is CRDI good? It is a technological breakthrough in diesel engines. If combined with VGT, it can surpass the performance of the normal efi gas engines of the same displacement both in POWER and ECONOMY. Is it that good - a big YES 24 hrs Le Mans race was won by an Audi CRDI diesel car
    #44
    It just expensive compared to gas engines and you really have to justify your mileage if the purpose of your car is to get from Point A to B...
    #45
    Common rail technology for me is the greatest advancement since Robert Bosch introduced a pump for automotive application. The injection pump is already precision but common rail system coupled with piezo equipped injectors redefines fuel delivery in diesels.
    In the hands of well equipped shops and properly trained technicians, any correction and malfunctioning component can easily be detected thus saving you costly repairs.
    Aug 2007
    #46
    I really believe in CRDi, however, Has anyone read the "Clash of the Titans" article in The Phil. Daily Inquirer?
    It compared the Starex vs. Hiace Grandia vs. Urvan.
    The Urvan was able to beat the Starex and Hiace in both power and fuel economy, and yet the Urvan doesnt have a CRDi engine, unlike the Starex and Hiace...
    It makes me start to doubt CRDi tuloy.
    #47
    Have not read that article. What was the weight to power and emission of all three?
    #48
    they have got to be kidding.. the URVAN is running a 2.7L engine (same with my previous service frontier elite)... lumalaklak yun ng fuel pag-rektahan at pagmerung load.
    kahit ilan pang owners ng nissan na naka 2.7L engine (TD27) sigurado akong the same ang observations nila.
    the test was probably nissan funded kaya bias towards nissan.
    ps. para matipid ang TD27, run it with 14" rims with 195/70 na gulong at run it between 80-120kph on 5th gear, para nasa 2K lang ang rpm.
    Aug 2004
    #49
    Quote Originally Posted by webmiester View Post
    Yeah, read it.
    Same route, but Tessa calculated fuel economy based on each vehicle's odometer... which is wrong. Look at the fuel consumed. They all consumed nearly the same amount of fuel... but driving on the exact same route, the variation in odometer trip readings was up to five or six kilometers off. In such light, the test has to be considered invalid.
    You don't do fuel consumption numbers without correcting for odometer error. From the looks of it, the Nissan had the fastest trip meter. So, guess what? It had the best calculated economy. That's fishy in and of itself.
    The testing methodology she used was good (and I enjoy her comparisons, I really liked the Spark/Getz/Picanto one... very informative), but her economy figures in that article were based on faulty data.
    Aug 2007
    #50
    Quote Originally Posted by wildthing View Post
    That's what I originally thought. However, I got to read part 3 (I only got to read parts 1 & 3) of the series which compared maintenance costs (costs of parts and labor for oil change, etc)... and in this part, it concluded that Toyota had the cheapest costs. Also,, in the third part, it noted the high resell value of Toyota, which Nissan might not enjoy as much because the Urvan was already an old model.
    Aug 2007
    #51
    Yeah, read it.
    Does this mean that their fuel mileage differences arent far apart anyway? The starex salesman had incredible figures for his fuel mileage which he claims was double that of the old starex. If the consumption isnt far from Nissan, then I dont think it would be "double" that of the old starex...
    Anyway, if the vans were driven on a convoy, the vans at the back would have less air drag and have an advantage in fuel economy
    What odometer error? Arent these things suppose to display the distance, that's all?
    Aug 2007
    #52
    AFAIK the Urvan in that Clash of the Titans thing is the only manual transmission among the 3, so fuel economy?
    Jan 2008
    #53
    CRDi is one of the greatest improvement in Diesel Engine Technology....Although the technology is a bit pricey but you can equate that to the performance and efficiency of the engine...
    Many are in doubt of CRDi technology, this is the same when the EFI engine was introduced replacing Carb engines... at first we encounter troubles and ECU problems which we thought at first cannot be solved by ordinary mechanics.. but now EFI engines can be diagnosed and repaired...Even the unrepairable ECU, now can be repaired
    Having a vehicle equipped with a CRDi engine is just like upgrading your HEADLIGHTS from HALOGEN bulbs to HID bulbs... Although HID Bulbs are expensive to purchase and maintain, still it is very efficient, low power consumption compared to Halogen
    #54
    Nice one sir nice one indeed.
    Jun 2008
    #55
    my former non-CRDi Strada beats my CRDi car today in terms of fuel economy.
    I regularly fill up my strada at average of 55 Liters full tank, and I get 550-580km liters from it.
    i fill up my present car at average of 62 liters full tank, and I get only 510-530km liters from it.
    all city driving.
    my verdict: good riddance to my strada. I always hated that tank of a vehicle
    Aug 2004
    #56
    If it's double the old Starex, good. The old Starex was kind of thirsty on diesel. Took it to Baguio, got a combined economy of 8.6 km/l.
    Doesn't matter in your typical convoy... and there's no indication of which van lead. Slipstreams have a positive effect on fuel economy if you're driving very, very close to the guy in front of you at speeds over 100 km/h. At your regular 80 km/h, the difference isn't crucial.
    You calculate fuel economy by dividing distance driven by number of liters used. If your odometer incorrectly displays distance driven, then your economy numbers are wrong. If one vehicle (apparently the Nissan) has an unusually fast odometer... then obviously, it would show better fuel economy than the other two.
    Many CRDis I've driven recently have not been quite as economical as old-school diesels... but who cares? They're faster, quieter, smoother and better in almost every other sense and they're still more economical than gas engines. The problem is that our local diesel is terrible, and as a result, CRDis have to be tuned conservatively (erring towards the safety side rather than the economy side) to prevent damage.
    Jan 2008
    #57
    if you need LOWER FC from your rides better maintain good driving habits...
    Try maintaining speed of 60kph - 80kph and you will see that you get LOW FC...
    eventhough you are running slow, you will still reach your destination no matter what...
    I always laugh when I see cars speeding at 140kph while i'm doing only 60kph in NLEX or SLEX or Coastal Road and at the end I meet them at the Toll gates, and sometimes i still get pass them at toll gates because they don't have EXACT Toll...
    we have a Mitsubishi L300 Exceed with 4D56 engine... used everyday travel of 35kms and for a week (245kms) it consumes 1 full tank of diesel. Speeds in coastal road of 100kph - 110 kph... but now maintain speed of 60kph - 80kph at coastal road for a week and it only consumed Half tank of diesel!!
    We sometimes complain of CRDi consumption of diesel higher, that is because we tend to drive these CRDi equipped vehicles faster due to their high torque and responsive engine... we cannot simply control ourselves and we always wanted its POWER and speed so FC is high...CRDi engines are very responsive.. I experience this with Kia Carens CRDi engine... at 2nd gear fully pressing the accelerator will surely pull everyone back to their seats.. and the first time riders are really amazed with the pulling power..
Is Common Rail Technology THAT Good???
