Results 11 to 13 of 13
- Apr 2005
- 5
April 28th, 2005 02:41 PM #11i have the same problem every morning.
car dies out after 5mins of starting.
i have to step on the gas for about a min (not to hard but just enough to rev it to about 1500rpm).
had 2 possible solutions
1) told my carb guy about the problem and after cleaning he mentioned a pinhole thing in my carb (forgot what its called) nagbabara daw yun kaya hirap. well enough after cleaning ok na yung start pero bumabalik ulit yung sakit (so i guess its off for another cleaning job)
2) my mechanic says that the carb has a "missing hose" sort like a pump that should feed gas at a steady pace. still havent found anybody knowledable enough about the carb to be able to fix it.
*Colt Lancer 78*
- 48
April 28th, 2005 08:21 PM #12Originally Posted by vin888
You can determine the heat range of the plugs judging by the number indicated in its model.
Higher number means its a colder plug.
Example:
NGK Sparkplug: BP5ES is hotter than a BP6ES
Denso Sparkplug: W20EXRU is colder than W16EXRU.
HTH!
April 29th, 2005 01:53 AM #13
thanks gian.
usually, colder plugs are used by high performance cars...such as cars with turbos...etc....
normal na dito sa pinas ang 6...some use 5 sa mga stock engines.
Traffic!
