Results 1 to 6 of 6
- Jun 2006
- 21
December 24th, 2007 07:02 PM #1Paano ninyo nililinis ang Simota air filter ninyo?
ginagawa ko lang kasi is babad sa diesel or gasoline, then warm water with soap.
btw, diba ang K&N kailangan pa lagyan ng oil after cleaning.
May alternative ba sa K&N filterchharger oil na iyan?
your inputs please...
- Jan 2008
- 32
January 20th, 2008 04:40 PM #3
With K&N you have to spray it down with a special cleaning agent and then put some oil on it,.. but for cheapskates (like me), we sometimes just wash it down with water or compressed air. (One caveat: strong water pressure or air jets may damage the filter).
Simota has it's own version of the K&N cleaning kit, but I don't really like their oil.
January 21st, 2008 03:03 PM #4
here's my two cents worth of (cheapskate) experience cleaning these gauze type filters.
first you run tap water (without using too much pressure) from the inside of the filter to help push the dirt out from the element. then mix a solution of grease-cutting dishwashing detergent and water. use a paint brush and gently brush the mixture on the outside pleats of the filter to further cleanse the element of dirt particles. rinse again from the inside without using too much tap water pressure. then air dry the filter before applying the filter oil.
NOTE: take care not to rinse or scrub with undue force since you wouldn't want to enlarge any of the miniscule perforations on the gauze material for larger dirt particles to come through. so using pressurized air is not a good idea!
as for the filter oil, the most practical cheap alternative is to find any kind of mineral based oil that wouldn't run off (too much) the pleats once applied. try not to use any kind of petroleum-based oil since this would possibly be harsh enough to damage the gauze material or the rubber part of the filter. this means that cleaning the filter with diesel or gasoline is not advisable also!
HTH
cheers mga kapatid!
January 21st, 2008 03:24 PM #5
here's what i do with my simota cone:
mix 1 cap of joy dishwashing fluid to half pail of water hanggang sa bumula
put the filter in the pail and just agitate it para matanggal dumi
rinse with running water (or dip it in a pail of clean water hanggang mawala yung detergent)
air dry (wag paarawan, wag bugahan ng compressed air, i usually allot 2 days for this)
spray with a little wd40 (don't use the straw, spray around a foot away)
January 28th, 2018 06:17 PM #6
