Results 1 to 9 of 9
- Jan 2010
- 11
April 16th, 2010 01:47 AM #1ask lang po ako regarding my car (Mazda3) yesterday i change my airfilter.. i put simota airfilter with pipe sya.. okey nman sya nung pauwi lumakas ang hatak but kaninang umaga when i start the car naka on na check engine ko.. dinala ko dun sa shop ang sabi.. gamit gamitin ko lng raw kasi naninibago pa yung makina coz iba daw pasok ng hangin.. is this true? natanong ko nman isang friend ko na naka simota rin.. okey nman daw sa kanya... bakit kaya? okey nman hatak nung car saka okey nman takbo..
April 16th, 2010 02:09 AM #2
- Jan 2010
- 11
April 16th, 2010 02:14 AM #3i tried to reset the ecu bt removing the battery connectors.. sa 1st start ko okey siya pero once na ioff ko and restart.. umiilaw ulit.. do i need to bring this to casa for the reading? or change it back to stock na lng? okey sana sya lumakas ang hatak and gumanda takbo ng car.. pansin ko lng ang idle rpm ko is nasa 600-700.. is that okey?
April 16th, 2010 04:07 AM #4
under warranty paba yung car niyo?
if yes then you should bring it to casa right away..
if no, am not familiar with mazda but try to adjust the idle and check the sensors that attach to the cone if any, kasi iba yung volume ng air ngayon kesa dati..baka may maluwag kaya umiilaw..
you mension your friend has the same setup? if yes then you should check the position of the sensors..
HTH
April 16th, 2010 08:44 AM #5
tingnan mo yung MAF Sensor mo sir kung nakalapat sa pinagdadaluyan ng bagong kabit na air filter mo.
April 16th, 2010 09:34 PM #6
mas maganda ma scan muna para malaman ang dahilan ng check engine light mo. madami na ngayon may mga obd scanner kaya you don't need the dealer to do it. mas maganda ma scan habang nakailaw ang check engine light.
- Jan 2010
- 11
April 16th, 2010 10:55 PM #7yeah.. thanks.. bukas try ko dalhin sa speedlab pra mascan.. hope maayos na to.. hehe
April 20th, 2010 12:19 AM #8
Your MAF sensor is connected to your stock intake pipe. You or the installer may have forgotten about this important piece of equipment on installation. CEL kasi error ang air flow na natatanggap ng sensor - 0 value. Better use only the air filter itself, and retain the stock air intake piping.
- Oct 2010
- 2
October 17th, 2010 01:51 AM #9San po pwedeng magpascan para sa check engine light na malapit sa pasay?
Traffic!
