Quote Originally Posted by mazyred1 View Post
i tried to reset the ecu bt removing the battery connectors.. sa 1st start ko okey siya pero once na ioff ko and restart.. umiilaw ulit.. do i need to bring this to casa for the reading? or change it back to stock na lng? okey sana sya lumakas ang hatak and gumanda takbo ng car.. pansin ko lng ang idle rpm ko is nasa 600-700.. is that okey?
under warranty paba yung car niyo?
if yes then you should bring it to casa right away..
if no, am not familiar with mazda but try to adjust the idle and check the sensors that attach to the cone if any, kasi iba yung volume ng air ngayon kesa dati..baka may maluwag kaya umiilaw..
you mension your friend has the same setup? if yes then you should check the position of the sensors..
HTH
