Results 1 to 14 of 14
    sirs,
    ano kaya possible problem ng car ko, kanina umaga habang papunta ako ng office namin bigla parang sinisinok yun makina ko plus pag nagbukas ako ng ilaw lumalabas yun check engine light...?? any one who experienced the same?
    ride ko nga pala sir is lancer 94 glxi..tnx
    Baka mababa ang voltage mo. Check the electricals first.
    check engine light is a signal that something is wrong in either the electronics, sensors or others. Best have a good mechanic take a look... or better yet, to your trusted casa.
    pa check mo sa casa. kc pag sa banawe ka pumunta d pa nila sure yun.. at least pag sa casa may warranty pa..
    Jan 1970
    pacheck mo alternator baka mababa charging . or baka madumi na air filter kaya parang nagchochcoke
    Jul 2003
    Ang sabi sakin sa casa, pag umilaw daw yung check engine light, posible rin sa computer box yung problema. maganda siguro punta ka na lang casa para sure ang pag-diagnose sa problema.
    Computer box, fuel filter, high tension wires, etc.. there are many possible culprit to pin point what made your engine choke.
    gusto ka kasi nila gawing milking cow kaya nila sinasabi agad na computer box ang problema or sira.
    tnx sa mga comments and sugegstions guys, ni try ko tanggalin yun connection ng battery, so far so good naman, d pa nagloko ulit.
    what it did is reset your computer box.. minutes after reconnecting the battery.. the computer will go on a sort of familiarization mode.. wherein it will map out the best and optimum settings for the current condition your engine is in....
    so.. baka nga naging ok.. kasi nakapagreset na ng settings yung computer to compensate for the "check engine"... pero still doesnt remove the fact na you had a problem to start with.
    Check engine means a lot of things.. you need a diagnostic computer to get the MIL code or the check engine code (kung ilang blinks) para mapinpoint mo kung alin talaga yung error.. by doing so.. you could isolate the problem.. and fix it.. before it does any more damage.
    As what others have pointed out.. it may simply be a HT wires problem.. to the worst an ECU problem.
    Sa mga panahon ngayon, even a loose fuel cap can trigger the check engine light...dami talagang possible factors.
    Jul 2003
    OOnga Otep. Di ko maintindihan why they cant just include the diagnostic computer sa car para naman di vague. even low octane fuel that strts knocking the engine will cause a check engine.
    May nabibili na nga for some cars na diagnostic computer. It's small lang. Pwede mo pa i reprogram ang computer for power or economy.
    Jan 2003
    My suggestion is for you to obtain the error code from the casa. They can run the diagnostic and they will probably charge you P200 to get the code using their diagnostic computer. The error code will also tell you exactly what caused the check engine light to go on. oftentimes, the culprit is an A/F sensor hiccup and this will cause the check engine light to engage. Once you find out from the casa what the error is, you can check on it yourself or bring it to a more affordable mechanic. Hindi ka basta maloloko ng casa na computer box kaagad ang may problema. Hope this helps.
    nangyari yan sa akin yesterday sa the fort... hiccups ang engine... pinatay ko then when I start, nag-start naman pero ON ang check engine na light... tinawagan ko ang very very very trusted mekanik ko... sabi ganito:
    1. check mo connection ng sensors lalong lalo na yung malapit sa air filter. baka natanggal or maluwang.
    2. kung nakakabit, 2 lang pedi problem niyan - sira sensors mo or ecu mo
    buti na lang maluwang lang ang pagka-kabit nung sensors... and sakto sinabi niya yung malapit sa air filter nga ang maluwang... akala ko may sira na...
check engine
