Results 1 to 5 of 5
    May 2008
    mga experts,
    good day
    may ikonsulta po ako sana sa inyo..due to heavy rains po kasi, wala ko choice kundi sumuong sa baha kasama ang lancer..although di naman kalayuan ung dinaanan na baha, ang identified na naging problema ko is ung brakes. although narepair na temporarily by replacing brake shoe, mas okay pa din na ipacheck kung may iba pang tinamaan ng pagsuong ko sa baha..mayroon ba kayong marecommend na shop na pdeng silipin ang possible effects nung pagsuong ko sa flooded area?umaandar pa naman po ung sasakyan pero mejo maingay na makina..may nakatry na po ba sa carsavers? okay po ba dun? if may marekomend po kayo shop, pareply na lang po sa thread na ito..maraming salamat po sa inyong lahat in advance..
    baka yun maingay is mga bearings lang ng alternator or compressor...
    had experienced that before. yung maingay dyan are the pulleys sa compressor tsaka yung belts.
    if this bothers you, bring it to speedyfix, since i think you are from mandaluyong.
    May 2008
    mga experts, thanks a lot po sa reply...i'll try po sa speedyfix, been their customer na rin naman po at wala namang prob..tanong lang din po, have you heard carsavers? meron po ba kayong alam na one stop shop na macheck na ung possible na tama sa kotse due to flood? gusto ko din po sana pacheck electricals in case..thanks po ulit.
    Nov 2003
    have you brought it over na? if nothing seems out of the ordinary i think everything should be fine pa.
help on flooded car
