Results 11 to 20 of 20
May 3rd, 2004 09:51 AM #11
if i were in ms chellay shoes, (i guess mababahuan din kayo, hehehehe! joke) id would rather sell the car and buy the same model. Add a little to find a perfect match for you preference.
wala ka pang problema kung saan magaling na mechanic mo dadalin and much worst, ba ka lokohin ka pa.
just a piece of advice and hope to help you...
May 3rd, 2004 02:26 PM #12
We overhauled our 1.3L Corolla in Marikina before and it cost us around 15K to change the timing belt/tensioner bearings, gaskets, piston rings, plus some suspension parts. All parts were OEM (bought it at MR2 in Banawe) and also included labor and machine shop costs. Whats important is that you have agood mechanic and you shop around for the needed parts.
If you get a surplus engine, its recommended that you recondition it as well (change timing belts, gaskets, etc) and the cost will just go up higher. Since your stock engine is a carb, you;'ll also have to do wiring work for the ECU and change your fuel pump as well.
- May 2004
- 7
May 3rd, 2004 07:21 PM #13jst to make things clear, undecided ako talaga to change/ to rerpair na lang.
ano yun mga dapat kong i consider para ipa overhaul ko lang cya, as i said Parts to buy: intake/exhaust valves, valve guides, valve seals, valve seats, overhauling kit, pistons, piston rings, main bearings, crankshaft bearings, oil seals, etc. an
PAG BLOW BY b eh yun na yun palit makina or pede rin gawin option yun overhaul?
May 4th, 2004 04:02 PM #14
An overhaul is the usual cure for engines with blown piston rings. The parts that you mentioned are the usual suspects when it comes to overhauling....
I suggest that you go for the overhaul.
- Feb 2004
- 129
May 5th, 2004 08:29 AM #15Originally posted by Chellay
I personally would go for the engine swap. It's not necessarily true na kung lesser ang displacement, mas economical ang kotse. Depende din kasi sa gearing yung fuel economy.
Here are the pros and cons behind both options:
A. Overhaul option
Pros:
1) 1/4 to 1/3 of the expense of an engine swap.
2) No need to rewire the car.
Cons:
1)Mabagal ang 1.3 liter 12-valve engine.
B. Engine Swap option
Pros:
1) Car has much more power, much more fun to drive and easier to merge into and pass slower traffic.
2) Bigger engine may have taller final drive ratio resulting in better fuel economy in the highway.
3) Overall value of the car improves.
Cons:
1) More expensive than overhaul
2) Need to purchase a matching transaxle for the bigger engine,
3) Need to buy ECU for new engine,
4) Need to have car rewired to accomodate ECU, its accompanying sensors and servos.
If it was my decision to make, I'd go with the engine swap.
BANNED BANNED BANNED
- 3,790
May 5th, 2004 02:58 PM #16If you're going to do a change engine, this article at www.toysport.com can give you some highlights on what to expect:
Cars registered in Japan must meet very strict and comprehensive tests, initially after 3 years and then every 2 years. The cost of complying with these test standards can run as much as 30% of the vehicle value. There are almost no cars over 6 years old running! Cars are recycled early, over 4 years old, the owner has to pay the yard to recycle!
.... the result is a lot of good engines being recycled or retired prematurely.
These engines are not street-legal (in US). The Japanese emission standards are tighter than the U.S. but emission controls are totally different.
.... some Japanese spec engines have higher compression and about 10-15% more horsepower, compared to U.S. engines.
These low mileage engines from Japan, however may have been sitting for a couple of months, and the internals are usually dry or rings may be frozen. We oil the cylinders and turn over the engines when we receive them. Engines are checked, but there is no way to guarantee against oil consumption or low compression.
There is absolutely NO WARRANTY on these high-performance engines.
.... we recommend “refreshing”- putting at least new rings, head gasket, timing belts (specially for the older units) and cleaning the oil pan and pump. This assures you that the engine you are installing have no maintenance problems."
I cut some lines (yung may ....)
The thing is, it is still IDEAL na ipabukas mo pa rin yung "bago" mong makina....so gastos ka pa rin.
So unless, you'd be upgrading to a higher displacement engine (1.6L na 4AGE/4AGZE), ipa-overhaul mo na lang ang orig engine mo.
- May 2004
- 7
May 5th, 2004 03:36 PM #17finally decided ako, ill go for overhaul, na realize ko hindi ako sure sa engine na ipappalit ko, gumana man bka by nxt year ipa overhaul ko na rin, kya overhaul na lang yun stock engine para sure, nxt time na lang ako mag papalit ng engine pag may big budget na eh yaw ko naman tipirin kong mag change engine ako, gsto ko lahat palit... tnx sa inyo
May 6th, 2004 09:47 AM #18Originally posted by Chellay
May 12th, 2004 12:02 AM #19
chellay, mabagal talaga 2e na engine ng xe and xl. naninibago din ako kase 4af engine ko dati. IMO, mas ok magchange engine to 4age high horse, medyo mahirap daw parts ng 20v na 4age. kelan mo plano magengine swap? siguro kung me kasabay ka mas mura? sa parts and shop ba?
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
