Results 11 to 15 of 15
December 8th, 2011 11:38 AM #11
afaik, low oil pressure, lots of blow-by and low compression pressures, eating up the oil, etc....if these occur at the same time, rebuild is the way to go.....but sometimes driving attitude, maintenance schedule will tell the mileage.
- Apr 2009
- 1,902
December 8th, 2011 11:51 AM #12Water jackets are on the cylinder head.
First off, check the compression.
If the top of the block is already exposed, check if the piston rings are still good. On most cases of high mileage use, you might want to change them together with the valve seals (that is if your engine "blows by").
In which case, I'd keep the block and everything on it (alternator, pumps etc).
If the water jacket rust can't be solved through shaving, I'd just get another cylinder head, probably from a D15B VTEC-E (rare though) since your ECU uses VTEC-E mapping.
So you retain everything and just change to a new cylinder head. Just don't expect gains in torque and power. At least you'll have your car running again at less cost.
- Nov 2011
- 28
December 8th, 2011 01:19 PM #13Oopps, sorry isa1023.. mali yata ung term na ginamit ko. ang ibig ko po sabihin ung gilid na yumayakap ng piston na meron water ay inubos na po ng kalawang. As far as cylinder head is concern, mejo manipis na din po sabi ng mekaniko. Possible daw na ilang beses na po nire-faced ung head.
Salamat po.
- Apr 2009
- 1,902
- Nov 2011
- 28
December 8th, 2011 04:14 PM #15salamat sir. Anyone from Paranaque who can help me with this? Reputable shops who could do the swap and if the shop could assist me looking for the engine the better
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
