Results 11 to 19 of 19
June 20th, 2018 09:43 AM #11
Sir by any chance kayo ba yung nabagsakan ng boulder sa Kennon road doon sa kabilang thread?
Same lang po sasabihin ko doon sa sabi ng iba. Ang daming pwedeng mangyaring kumplikasyon sa conversion. Tapos kung magawa man ng maayos, babaratin din yan ng husto pag ibebenta mo na. Kung may bibili.
Pwede sana kung makahanap kayo ng same model (4x4, 3.0 diesel) na engine lang ang sira. Price ng transplant at cost nung kaha na lang ang konsiderasyon.
June 20th, 2018 11:20 AM #12
June 20th, 2018 02:26 PM #13
Lol classic case ng nagbabasa ng mabuti.
Its a good project if you like this kind of things. If it was me i will go with what you are intending. Mahilig kasi ako mag DIY sa kotse ko.
If you are not so adept with cars or if you dont know a shop owner then i suggest to declare the car as a total loss and buy a used diesel fortuner instead.
- Aug 2016
- 8
June 20th, 2018 09:27 PM #14
- Oct 2012
- 4,851
June 20th, 2018 10:14 PM #15
- Apr 2009
- 429
June 24th, 2018 02:07 AM #16I will probably put that 1KD FTV 3.0 D4D eng on a Prado 120 or to a Hilux LN106... as long as it has its ECU and all. Putting it in a gas-fed fort is a waste of time with lots of headache. I mean its not probably bolt on. Kung talagang gusto mo, Baka pwede pa ung 4x2 2.5 Fort ang recipient then change its front end with the 4WD to make it work its 4x4...
but the best route pa rin is to sell that engine then buy a 3.0 Fort 4x4. No issues
June 24th, 2018 10:22 AM #17
Actually... Possible yung gusto gawin ni Jeffy07...
Kaya lang... For sure mawawalanbna ng resale value yung converted Fortuner mo...
2nd, mas mabigat at malaki yung diesel engine, alangan ako sa front suspension.
3. Electrical... May heater and diesel which is not available sa ignition ng gas version... Lalagyan mo ng bypass switch sa dashboard?
If the car is 15-20 years old, I personally will experiment...
Sent from my ASUS_Z017DA using Tapatalk
- 52,731
June 24th, 2018 10:34 AM #18as recommended by others,
buy a pre-owned diesel fort. or a cheaper innova.
pera lang ang kelangan. walang kapagod-pagod.
sell whatever is sell-able from your old ride's front end. olx it for free. mabebenta rin yan. even scrap metal has some value, however small.
good luck, po.
June 24th, 2018 11:36 AM #19
Putting that 3.0 D4-D engine on a Prado seems a good idea. What they said is true. The suspension of a gas and diesel fort maybe different. Since diesel engines are significantly heavier than their gas counterpart.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
