Results 1 to 8 of 8
    Jan 2011
    Yesterday, everything was working just fine. The CEL switches off in 5 seconds or less, but after raining today, the CEL turns off 5 minutes after.
    BTW, my car is parked outside so it was drenched in the rain...
    This also happened to me a month ago when I washed my car, but after a day or two, it went back to normal.
    Can anyone explain why this happen? TIA...
    Jun 2005
    it would help if d car make and model would be indicated...
    anyway, it is a wiring problem. may nabasang wire or sensor. check under d hood for watermarks that would tell kung san nababasa. you can also have the ecu scanned
    Jan 2011
    Quote Originally Posted by sirkosero View Post
    Ooops.. I haven't mentioned my ride, sorry. It's a 95 Civic ESi.
    Sir I had popped the hood up to check for watermarks, so far I have seen none naman.. Where should I check specifically? Pardon my ignorance because I'm just a new (secondhand..) car owner..
    Jun 2010
    tama sila paps either wiring, sensor, or ecu or fuse. dalhin mo lang sa auto electrician mahirap mag DIY lalo na pag electrical
    Jan 2011
    Quote Originally Posted by ReXBadBoy View Post
    Ok.. thanks for the advice! I was just dumbfounded when the CEL takes 5 minutes to switch off just because of the rain. Dati naman kasi 5 seconds lang, it's already gone..
    Could it be that the engine is still cold?
    Quote Originally Posted by r1chm0nd View Post
    A cold engine will not throw a CEL warning. It's probably a sensor that has gone "bad" from age.
    Just go to a competent auto-shop to have it diagnosed and fixed.
    I would suggest SPEEDYFIX (San Juan) or SPEEDLAB (Quezon Ave) as places to go.
    Jul 2010
    lahat sila tama,baka me sensor lang na sira.
    o baka naman kailangan mo ng update ng computer ng sasakyan mo?
    Go na sa workshop na nabanggit ni broGH.
    replacing all the few electrolytic capacitors on the ECU might just fix your problem as some other owners experienced
    but capacitor problem does not explain what appears to be temperature dependent symptom in your case ... so this is just a try-if-it-works approach and it won't hurt your wallet
CEL doesn't turn off in a few seconds.. Help please..!!
