Results 11 to 14 of 14
October 26th, 2008 06:39 PM #11
thanks ghost, try ko drop by kay Nodalos, mahal sobra pag sa dealership.
userfriendly, pag wala ako talaga mahanap siguro patangal ko nalang...
pag naka gasoline, mabaho amoy ng exhaust... pag LPG wala amoy
pano kaya nasira iyun catalytic converter? 50 thousand kilometers lang natakbo car ko...
October 26th, 2008 06:57 PM #12
- Aug 2015
- 4
August 11th, 2015 03:50 PM #13Mga paps same ng problem ko yan. Ok lang ba kahit sira yung cat converter o mas magandang ipatangal nlng yun. Thanks in advance.
August 11th, 2015 09:32 PM #14
There are two parts to the cat con. First, the reduction part where oxygen is freed from NOx(oxides of nitrogen) resulting in N2 and O2. The freed up O2 is then (second), oxidation catalyst, used to burn CO and unburnt fuel (HC) resulting to CO2 and H2O. What leaves the tail pipe are O2, CO2, N2 and H2O all of which are inert or non polluting except now CO2 is causing global warming
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
