Results 41 to 50 of 79
July 2nd, 2010 12:54 AM #41
Dear dannybe:
There are very few people I would trust to tune those Solex carbs - they really have to know what they are doing.
The people that I do know and trust are not cheap - OK ba budget mo?
When I used to have performance carbs myself (mainly twin-downs, Mikuni Kogyo Solex, Aisan and Weber downdrafts) I cleaned them with lacquer thinner.
It has no residue and will remove most of the varnish and gum in the carb.
The most important thing to remember after soaking the carb for a day in a CLOSED gallon or small drum of lacquer thinner is to DRAIN it immediately and BLOW DRY ALL PASSAGES and CHAMBERS with compressed air.
Never leave a carb with any fluid in it for a long time - corrosion and water condensate will get to it and DESTROY it.
As long as the passages are clean then its probably OK.
Note:
The reason why I used twin downs vs twin sides is very simple - twin downs are very STREETABLE - you can use them to go to work, pick up the wife and kids, and IDLE DECENTLY with the A/C ON in Metro Manila traffic.
No twin sides can do that consistently - that's why NO manufacturer used them on STANDARD vehicles - I'm NOT referring to high-end sports cars - but even they tend to use progressive down-drafts more than side drafts.
Even if you have a complete set of choke tubes, boost venturi's, jets and emulsion tubes, if the weather changes from hot, bright and sunny to cool and rainy - your twin sides will LOSE their TUNE - nothing you can do about it unless you're prepared to re-tune in the middle of the rain.
Of course that's just me - to each his own.
Good Luck and Best Regards,
Dusky Lim
P.S. Keep on tuning
- Aug 2008
- 24
July 2nd, 2010 10:44 AM #42Hi Dusky,
If the work is worth it then i dont mind the costs just as long as they are reasonable. I dont know if all the jettings are clear though so i have to have them checked.
The carb builders will also have to tune the carbs after they are bolted on the engine so preferably within makati, mandaluyong pasig area.
what i have now are the carbs and the repair kits with a new main jet which are ready for work to be done.
thanks for the help.
July 3rd, 2010 12:19 PM #43
Dear dannybe:
Nag pm ako sa yo, please pm me back for a reply.
Regards,
Dusky Lim
- Feb 2008
- 25
August 9th, 2010 06:54 PM #44Hi fellow tsikoteers, My problem is high idle speed. around 1500 rpm. i have a hitachi twin carb (from 1980 datsun 180B i think) installed in my nissan stanza model 85. anybody here familiar with this kind of carb? TIA
- Nov 2008
- 641
August 11th, 2010 05:23 PM #45Sir Duskylim,
I would like to ask your expertise on this please:
I have this Carbureted 4g63 SOHC 88 Galant. My problem is that, the Air adjust screw seems not to be working, I mean, I tried adjusting it but nothing's happening to the idling. I tried screwing it IN to the max but the idle stays, and tried to screw it OUT without removing the screw, but still nothing happens. My sparkplugs seems to be filled with black dry carbons everytime I check it (might be a sign of a too rich mixture). Also, my exhaust pipe emmits a gasoline odor.
I would like to ask your suggestions / reco if what are the possible causes and what are the things which I can check or do to fix it.
Thank you so much for your reply
August 12th, 2010 11:12 AM #46
Dear jvnj:
Clearly you have a serious carburetor problem, you should have it dismantled and overhauled by a competent repair shop.
If you cannot adjust the mixture on curb idle and your plugs burn rich all the time, you are also wasting a lot of gas.
If you do NOT know a good shop I will recommend one but I must ask the first if they are free.
Now they are a little pricey so PM me if you're interested.
Best Regards,
Dusky Lim
- Nov 2008
- 641
August 13th, 2010 08:05 AM #47Sir Dusky,
Sorry for the late reply, had a very busy day at work yesterday. Anyway, thank very much you for your recommendation. You're very right about the fuel consumption, seems I'm only having about 6km a liter. By the way Sir, can you possibly tell me where the recommended shop is? I'm basically located here at Biñan Laguna, hope you can recommend a good carburetor shop somewhere here or in Las Piñas City.
Again, More Power and thank you so much for the assistance!
August 13th, 2010 05:17 PM #48
Sir:
I myself come from Fairview here in the QC.
So sad to say the shops I'm familiar with are from QC also.
I repeat PM me if you're interested and I will call them to make an appointment for you.
Sincerely,
Dusky Lim
- Aug 2010
- 4
August 26th, 2010 07:29 PM #49Hi mga Sirs. Kelangan ko pong magpaoverhaul ng carburetor. San ba may magaling sa bandang sucat, paranaque at las pinas? Please naman po kasi palyado na andar ng fx ko at isa pang malaking problema eh namamatayan na pag nakaaircon. Idle ko nasa 800rpm w/o a/c, 1100rpm naman pag may aircon tapos pag nag automatic off yung compressor bumababa ng 400rpm then hirap nang makarecover. Help naman po, bago lang ako dito at di masyadong marunong sa sasakyan.
- Aug 2010
- 4
The 1.5G is good enough for me tbh My current car doesnt even have a rear camera and Ive never...
All New Toyota Corolla Cross
