Results 11 to 18 of 18
July 29th, 2009 11:00 AM #11
Ignition coil yan bro, of that I'm 100% sure. Nangyari din yan sa akin recently (pero 97 Accord). I suspected a lot of things, pati na rin main relay, pero ganun pa din. Napagastos lang, hehehe.
Nung napalitan na yung ignition coil, ok na.
Most probably, nasa loob ng distributor yung ignition coil ng Civic. Less than 1k lang malamang yan sa suking auto supply, mga 2.5k siguro sa casa.
- Jan 2009
- 123
July 29th, 2009 11:22 AM #12Di ba sakit ng Honda, ang faulty ignition coil? Anyway, try to search on google, hard hot engine start.
July 29th, 2009 11:45 AM #13
our civic esi 93 also had taht problem pagkatapos mo gamitin ayaw na mag start ulit kailangan palamigin pa engine haha. pinagawa la ng namin sa banawe sa ignition module/coil ata pnalitan lang
August 9th, 2009 12:19 AM #14
Ignition coil yan. Nangyari na rin sakin yan. Every 6 months yata palit ako ignition coil, di ko na nalaman ang totoong culprit kung bakit lagi nasisira kasi nabenta na tsikot bago ko mapa check kung ano talaga ang problema.
- Oct 2005
- 64
August 10th, 2009 05:44 PM #15sa ilalim ng distributor pwede mo macheck visually yun ignition coil. I have 2 honda civics that had the same problem after 5-10 years of usage. crack na yun case ng ignition coil kaya ayaw magstart pag mainit na makina. in due time hindi na talaga magstart yan
August 11th, 2009 02:48 AM #16
Sa lahat na may Honda pasyalan ninyo ang site na ito, baka makatulong sa problema.
[SIZE=3]Honda Hot Start Problems - Troubleshooting a Hot No Start Problem in ...[/SIZE]
If your Honda Accord, Civic, Prelude, CRX or other won't start when it's hot, ... You might have a hard start every now and then, but not enough to really cause ...
autorepair.about.com/od/enginetroubleshootin1/a/honda_hot_start.htm
- May 2010
- 1
May 2nd, 2010 01:32 PM #17My car is honda esi 95 model, hard starting when engine is hot (hard cranking), but no problem when engine is cold, it starts normally. i checked ignition coil, i found no crack, i noticed burn mark beside the ignition coil casing, is this a sign of bad ignition coil? or the cause of the problem?
- Nov 2008
- 148
October 20th, 2011 12:24 PM #18
