Results 1 to 10 of 18
- Jul 2009
- 4
July 24th, 2009 10:21 AM #1need help mga sir.. my car is 96 civic,vtec engine.. my problem is after driving it around mga 30mins. & when i turn off d engine and turn it on again hrap na sya mg-start..pro di nman ako nmmatayn ng makina.usually klangan ko pa palamigin ung engine. pro pg malamig nman engine,1 click lng sya..npalinis ko na ung sa my trottle nya &replace na rin fuel filter.. pls help mga sir..
July 24th, 2009 10:28 AM #2
umiikot ba starter pag iniistart mo? malakas ba ikot?
if so, could be an ignition issue. if not, check the battery contacts kung mahigpit, or, baka mahina na battery mo.
July 24th, 2009 10:30 AM #3
mukhang mahirap problema niyo sir ah, natry niyo na po ipacheck sa kakilala? try niyo icheck sir yung spark plugs baka hindi na makaemit ng sparks pag mainit.
- Jul 2009
- 4
July 24th, 2009 10:30 AM #4need help mga sir.. my car is a 96 civic vtec.my problem is after driving it around 20-30mins,and when i turn off d engine and start it again ayaw nya na mg-start minsan hrap mg-start.klangan ko pa palamigin ung engine pra mg-start,pro pg malamig ung engine lalo na sa umaga 1 click lng sya. npalinis ko na po ung sa my trottle and replce d fuel filter.. pls. help me mga sir.. thanks!
Tsikot Member Rank 3
- Nov 2002
- 1,757
July 24th, 2009 10:45 AM #5di ko alam kung may ignition coil pa yung car mo, pero kung meron, pwedeng ito ang reason.
THE AUTO SPECIALIST
- Mar 2006
- 607
July 24th, 2009 11:54 AM #6check for spark and if no spark, suspect igniter
check fuel pressure and if no fuel pressure,suspect the main relay
- Jul 2009
- 4
July 24th, 2009 11:55 AM #7mlakas nman ung redondo ng starter,mhigpit din ung terminals ng battery..kpapalit ko lng ng spark plug 3 weeks ago yta (bosch platinum)..nung tsek ko 2days ago maitim sya den nilinis ko,test drive ko mga 1km den off ko ung mkina den on ko uli ok nman.2x ko inikot,ok nman. den nung ngp-gas ako sa shell,mga 3 km.yta natakbo ko ganun na nman ayaw umistart.wait ko pa mga ilang minutes pra umistart pero klangan tapakan ko pa ung gas nya kc prang mamamatay..
THE AUTO SPECIALIST
- Mar 2006
- 607
July 24th, 2009 12:19 PM #9
Not familiar with Civics, but it really could be the Ignition Coil (or ignition module if it has one). Same symptoms...
- Dec 2008
- 9
Daming issue ng SU7:grin:
Xiaomi E-Car
