Results 1 to 18 of 18
    need help mga sir.. my car is 96 civic,vtec engine.. my problem is after driving it around mga 30mins. & when i turn off d engine and turn it on again hrap na sya mg-start..pro di nman ako nmmatayn ng makina.usually klangan ko pa palamigin ung engine. pro pg malamig nman engine,1 click lng sya..npalinis ko na ung sa my trottle nya &replace na rin fuel filter.. pls help mga sir..
    Apr 2004
    umiikot ba starter pag iniistart mo? malakas ba ikot?
    if so, could be an ignition issue. if not, check the battery contacts kung mahigpit, or, baka mahina na battery mo.
    Apr 2009
    mukhang mahirap problema niyo sir ah, natry niyo na po ipacheck sa kakilala? try niyo icheck sir yung spark plugs baka hindi na makaemit ng sparks pag mainit.
    need help mga sir.. my car is a 96 civic vtec.my problem is after driving it around 20-30mins,and when i turn off d engine and start it again ayaw nya na mg-start minsan hrap mg-start.klangan ko pa palamigin ung engine pra mg-start,pro pg malamig ung engine lalo na sa umaga 1 click lng sya. npalinis ko na po ung sa my trottle and replce d fuel filter.. pls. help me mga sir.. thanks!
    di ko alam kung may ignition coil pa yung car mo, pero kung meron, pwedeng ito ang reason.
    check for spark and if no spark, suspect igniter
    check fuel pressure and if no fuel pressure,suspect the main relay
    mlakas nman ung redondo ng starter,mhigpit din ung terminals ng battery..kpapalit ko lng ng spark plug 3 weeks ago yta (bosch platinum)..nung tsek ko 2days ago maitim sya den nilinis ko,test drive ko mga 1km den off ko ung mkina den on ko uli ok nman.2x ko inikot,ok nman. den nung ngp-gas ako sa shell,mga 3 km.yta natakbo ko ganun na nman ayaw umistart.wait ko pa mga ilang minutes pra umistart pero klangan tapakan ko pa ung gas nya kc prang mamamatay..
    add ko lang if no spark possible ignition coil din
    Feb 2005
    Not familiar with Civics, but it really could be the Ignition Coil (or ignition module if it has one). Same symptoms...
    Dec 2008
    sa akin naging culprit is the starter
    Sep 2004
    Ignition coil yan bro, of that I'm 100% sure. Nangyari din yan sa akin recently (pero 97 Accord). I suspected a lot of things, pati na rin main relay, pero ganun pa din. Napagastos lang, hehehe.
    Nung napalitan na yung ignition coil, ok na.
    Most probably, nasa loob ng distributor yung ignition coil ng Civic. Less than 1k lang malamang yan sa suking auto supply, mga 2.5k siguro sa casa.
    Jan 2009
    Di ba sakit ng Honda, ang faulty ignition coil? Anyway, try to search on google, hard hot engine start.
    our civic esi 93 also had taht problem pagkatapos mo gamitin ayaw na mag start ulit kailangan palamigin pa engine haha. pinagawa la ng namin sa banawe sa ignition module/coil ata pnalitan lang
    Nov 2007
    Ignition coil yan. Nangyari na rin sakin yan. Every 6 months yata palit ako ignition coil, di ko na nalaman ang totoong culprit kung bakit lagi nasisira kasi nabenta na tsikot bago ko mapa check kung ano talaga ang problema.
    Oct 2005
    sa ilalim ng distributor pwede mo macheck visually yun ignition coil. I have 2 honda civics that had the same problem after 5-10 years of usage. crack na yun case ng ignition coil kaya ayaw magstart pag mainit na makina. in due time hindi na talaga magstart yan
    May 2007
    Sa lahat na may Honda pasyalan ninyo ang site na ito, baka makatulong sa problema.
    [SIZE=3]Honda Hot Start Problems - Troubleshooting a Hot No Start Problem in ...[/SIZE]
    If your Honda Accord, Civic, Prelude, CRX or other won't start when it's hot, ... You might have a hard start every now and then, but not enough to really cause ...
    autorepair.about.com/od/enginetroubleshootin1/a/honda_hot_start.htm
    May 2010
    My car is honda esi 95 model, hard starting when engine is hot (hard cranking), but no problem when engine is cold, it starts normally. i checked ignition coil, i found no crack, i noticed burn mark beside the ignition coil casing, is this a sign of bad ignition coil? or the cause of the problem?
    Quote Originally Posted by kahoy_1 View Post
    Similar yung problem ko dito but my car is 1st gen crv matic. Na-solve mo na ba ito?
car won't start when engine is hot..
