Results 1 to 17 of 17
    Nov 2007
    hi guys
    after maghatid sa SM car wont start na, anu culprit nito ?
    pag crank nya mamatay din agad
    nissan lec 94
    Nov 2007
    1)starter
    2)fuel pump
    Dec 2007
    3) uh, sinungaling na fuel gauge? baka wala nang fuel at sabi ng gauge, "isipin mo na lang, meron pa" (this happened to me while on a test drive )
    Nov 2007
    Quote Originally Posted by woohoo View Post
    hahahaha...
    chinok ko na lang ung carbs linisin ko bkas ung carbs huhuhu
    Oct 2008
    check the battery
    Nov 2003
    have the carb inspected. see if there is fuel going to the engine.
    Nov 2007
    battery is okay naman
    tapos kanina namatayan ulit ako ... incline pa naman.. nung nag rev ako biglang namatay parang nawalan ng hininga eh
    tapos first crank ko ayaw, pangalawa ayaw pa rin, pangatlo okay na
    kapapalit ko lang fuel filter a few months ago (June or july cant recall). sinabay ko ito nung nagpalit ako ng spark plug at tune up
    nalinis ko na rin ang carb..
    is this on fuel pump? kng fuel pump magkano ba fuel pump? how long would it take to install?
    any other symptoms
    TIA
    Nov 2007
    what is the symptoms kng fuel pump ang problem?
    in relation to my toy problem.. fuel filter na nilagay ko ung maliit lang not the OEM or standard for my Car is this could be the trouble?
    Nov 2007
    UP ko lang po
    Quote Originally Posted by jansky View Post
    You don't have to use OEM but is the aftermarket filter made for your car? If it's not it could be the problem, did the problem start after you changed filters?
    Nov 2007
    well it only happen twice after i change the filter (june or july)
    and this all happen in inclined situation (stop and go) "stalled"
    I think is there is no gas being pumped (once)
    and other is , although the engine is running but it wont accelerate (once) so this is inclined situation too
    volume test mo yung fuel pump
    at least .8L/ minute
    if volume is ok, carb internal problem na yan , kailangan i repair
    Nov 2007
    pde pa ba sa linis ung carb ?
    i think this is a carb problem, maybe it's time for a carb overhaul
    Nov 2007
    how much would it cost kaya? for carb overhaul
    2 pede pagmulan nyan : Electrical or Fuel System.
    First of all isolate mo muna problema
    1. kung meron yan ignition coil, hugutin mo ung high tension wire tapos lapit mo ng konti sa engine mga 1mm na gap (mag gwantes ka ng pang electrical kasi malakas koriente nito magugulat ka)
    2. Pa crank mo ung engine habang tinitingnan mo kuna mag korienteng tumatalon. pag meron malamang fuel system.
    Tanggalin mo air cleaner tapos pa bumba mo acc pedal (ng hindi umaandar ang makina) habang sinisilip mo kune meron bumobombang gasolina. Pag wala lumalabas, flash light mo kung ano sa dalawang side ng carb ang bumubukas pag mahina lang ang bomba, lagyan mo un ng isang takip ng break fluid na gasolina tapos pa start mo, pag mukhang aandar ibigsabihin delivery ng gasolina ang problema. Lagyan mo ng gasolina ung loob ng carb (hindi ung loob ng intake manifold). par marami na laman pa start mo ulit pag umandar at nag menor malamang ang problema mo eh ung fuel filter or ung filter ng carb sa loob.
    May 2004
    Quote Originally Posted by bambino View Post
    pano po mag volume test ng fuel pump?
car wont start
