Results 1 to 10 of 10
- Apr 2004
- 66
December 8th, 2011 12:11 PM #1good day guys,
i am having problem with my honda crv 2004 b20 engine, the engine wont pass 5000rpm under load? any idea on what to do or fix , i already change the plug and engine oil. tnx and God bless all!
December 8th, 2011 12:16 PM #2
- Apr 2009
- 1,902
December 8th, 2011 12:22 PM #4Ganyan din po yung nangyari sa engine ko dati.
Found out it's because of the HKS mushroom type filter sucking not enough air under high rpm with engine load.
Try niyo po muna without the air cleaner, which is possibly dirty and won't let more air pass through.
OT:
Di po ba K series ang engine ng CRV?
K20 and K24?
December 8th, 2011 12:41 PM #5
rev limiter 5000 rpm?
i don't think so
stock CRV B20 VTEC revs past 6000
December 8th, 2011 12:55 PM #6
check the engine oil level. have you changed the engine oil just recently? the vtec might not be actuating or the vtec sysem oil gallery is plugged. what is the V.I.N.? was it designed for the U.S. market?
December 8th, 2011 06:43 PM #7
A few possibilities. One, VTEC is not engaging, so it's choking for air past 5000 rpm, but it should feel like it's running out of air, not a hard cut.
Two, ignition coil or improper timing (belt has jumped a tooth)
Three, ECU issue.
Four... something else.
Best to take it in to a mechanic who knows his B-engines and have him take a look.
- Apr 2004
- 66
December 8th, 2011 06:47 PM #8sory guys, my bad... it's the k20 series not the b20, will try to change the air filter and clean the maf sensor... will post back soon if it change anything! tnx tnx.
btw... when im moving and in gear, if i depress the clutch, and floor the accelerator. it will pass and hit the rev limiter. only when in motion. but not at stand still. so im really confuse.
- Jul 2003
- 573
- Nov 2007
- 329
December 19th, 2011 12:16 PM #10Based on my experience, Civic FDs are rev limited up to 5000RPM if you're not moving. But when you're moving, it revs all the way to 7000RPM. Probably a safety feature? It might be the same with the CRV.
Hybrids and EV
