Results 1 to 10 of 10
- Oct 2011
- 4
October 2nd, 2011 10:15 PM #1guys need help . . . bumabagsak kasi rpm ko pag bitaw ng gas lalo na sa umaga. bumabagsak na halos mamatay yung makina lalo na pag naka a/c, minsan khit wlang a/c bumabagsak din to almost zero. pero pag tumagal/uminit na nagiging stable na yung rpm nya to 900 . . .
napacheck ko na yung fuel filter, cleaned the throttle body and iacv, newly change spark plugs and ignition coil. . .. btw honda civic vti 97 po yung ride ko . . . TIA
October 2nd, 2011 11:11 PM #2
October 3rd, 2011 12:35 AM #3
same here. sakin pag naka aircon then going to a full stop from 900 bababa siya to 600-500. nagpalinis ako ng IACV after nun ok na siya pero bumalik din. sensors din kaya problem dun? car is sentra series 3
- Oct 2011
- 4
October 3rd, 2011 06:51 AM #4thanks for the reply ghosthunter . . . will do visit speedyfix . . . actually ive been their last friday and yun din po sabi ni sir migs of speedyfix na baka yung temperature sensor ang problem ng auto ko.
October 3rd, 2011 11:23 PM #5
a full scan will reveal the problem but most probably may problema with the engine cold....something with the iacv, thermostatic air cleaner, etc...
- Apr 2008
- 51
October 4th, 2011 12:40 PM #6i experienced the same problem with my vios years ago and tried several attempts to correct to no avail. At that time, i bought my own OBD II scanner and found out out several error codes suggesting clues, not specific to any sensor, pointing to a lean state.
the real culprit to my problem were leaking gaskets.
symptoms are low rpm, hissing sound at the engine bay, engine bad when cold, runs fine when hot but lacks acceleration
note: check engine light is off even with symptoms, the light only turned on after a few weeks
- Oct 2011
- 4
October 8th, 2011 08:47 PM #8*snowblind - sir nkapagpalit nako ng new iacv kanina but still ganun pa din sya. npacheck ko na din mga sensor ko sa Motor Doctor using their OBD scanner . . . ok nmn daw mga sensor ko . . . they also check for vacuum leak pero wla naman daw . . . bka next sat yung temp sensor palitan ko na din . . . hopefully mag ok na sya
- Oct 2011
- 4
October 11th, 2011 08:43 AM #9update lang mga sir . . . may nabasa akong thread sa civic forum na possible cause ng rough idling is that there is an air in the cooling system . . . kya nagtry ako na i-bleed yung air . . . kya lang wala yatang bleed screw ang civic 97 kaya ang ginawa ko is that I open the radiator cap and turn on the engine for 15mins. and kanina nung ginamit ko yung auto . . . ok na sya hindi ko na naexperience yung biglang bagsak ng rpm.
- Apr 2009
- 1,902
October 11th, 2011 10:27 PM #10
Daming issue ng SU7:grin:
Xiaomi E-Car
