kulotz,
every parts store should have a spark plugs substitution catalog. the factors determining what spark plugs to use are:
1. heat range
2. reach- the threaded barrel length or your plugs might puncture your pistons
3. thread size-14 mm or 19 mm(1940's cold running vehicles)
4. resistor or non-resistor ( resistor to reduce electromagnetic interference and radio frequency interference)
5. seat type- gasket type or tapered seat
6. socket wrench size- 5/8 ", 13/16", 7/8"
7. tip design- single ground, twin ground, four ground, barrel ground
8. tip material- nickel, platinum or iridium
9. gap design
the platinum and iridium are used because they are designed for 60-100kmiles intervals between tuneup (labor is expensive outside of the third world countries, yomsayin'). if your engine is run at optimum performance, not too cold nor too hot, and the air/fuel mixture is around 14.7 pounds of air per 1 pound of fuel, it should last up to 60k miles
jick
instructor
guam community college
