Results 21 to 23 of 23
- Jul 2010
- 570
June 24th, 2013 09:12 AM #21Temporary solution lang iyan.
The best solution ay palitan yun lumang or nanigas na mga valve seals. Hindi maganda ang sealing kapag matigas yun rubber. Kaya nasisira ang valve seals ay dahil overheating ng engine.
Ang simple way para malaman kung sira valve seals ay tangalin muna spark plug at tignan kung may oil or oil na sunog sa spark gap nito. Pa Top Overhaul muna engine bago palitan ng mga spark plug.
June 27th, 2013 06:25 PM #22
June 27th, 2013 06:52 PM #23
there is a way to change the valve seals without removing the cylinder head. if you lap the valves, the clearance will change and the adjusting shims are a PITA (pain in the ass) to change.
http://repairguide.autozone.com/znet...52802665d9.gifLast edited by jick.cejoco; June 27th, 2013 at 06:56 PM.
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
