Results 1 to 7 of 7
March 23rd, 2010 12:00 AM #1
Bros,
Need your advice. I bought two oil seals - camshaft and crankshaft when I was in Manila last week. When we were to install it last Sunday, we discovered upon opening of the timing belt cover that wala naman ang leak doon. You might ask why I concluded na dun ang leak, dati kasi I already replaced these two oil seals, which were leaking. Natural assumption ko dun pa rin. Yun pala, may leak na pala between the head and the block. Coolant loss was also noticed by me during the past two weeks.
My questions:
1. Wala naman kayang other parts na natamaan? FYI, I do not suffer from power loss what soever. Still averging 90 to 120 kph on the highways.
2. What other parts do I need to undertake cylinder head gasket replacement, does it need to be an OEM part or replacement ok lang?
3. Di pa naman kaya crack head ko?
Feel free to make dagdag questions, suggestions, or information on this matter. Sayang din ang knowledge that we may learn.
Thanks and God Bless mga bro.
- Aug 2004
- 164
- Jun 2008
- 1,741
March 23rd, 2010 07:04 PM #3Derecho mo na top overhaul dahil papalit ka rin naman ng head gasket.
cracked cyl head? Kung walang previous overheating and no water traces sa itaas ng piston eh masabi natin na ok ang cylinder head. Safest syempre ay pressure test ang head pag tinanggal sa engine, or check for crack using "spot check spray".
- Jul 2003
- 573
March 24th, 2010 08:23 PM #4minimum parts you will need:
1. cylinder head gasket
2. valve cover gasket
3. intake manifold gasket
4. exhaust manifold gasket
5. sparkplugs ring/seal if equipped
April 4th, 2010 12:19 AM #5
better to have the cylinderhead pressure tested(crack test) since mag top overhaul ka naman.it wont take an hour pag di busy yun machine shop. so nag mix ba yun oil and water?
April 10th, 2010 09:43 PM #6
Napa top overhaul ko na mga papi. Cost me around P8k, parts replaced were cylinder head gasket, intake manifold/exhaust manifold gasket, valve seals. No machine shop was made, di pa naman nagwawarp ang head. Naagapan daw. Have broken in the engine also, traveled around 600kms to and from Carles, Iloilo to Roxas City, Capiz and back to Iloilo City last holy week. After break-in binalik ko muna sa casa for setting of valves kasi yun din ang advise nila. So far so good naman mga bro.
April 11th, 2010 09:40 AM #7
Suzuki JIMNY [merged threads]
