Results 11 to 17 of 17
July 7th, 2004 10:40 PM #11Originally posted by vinj
Is your engine eating up oil? Is there white smoke coming out from the rear?
The best way to check if you're already blowby is to have the car compression tested.
One week na wala pang nabawasan sa langis bagong change oil siya... pina check ko kanina me problem daw cylinder gasket... pwedi bang mag labas ng white smoke sa dipstick yun? only problem ngayon nawawalang ng tubig kasi nilalabas ng radiator and sana nga cylinder gasket nalang
Maraming salamat po sa mga reply
July 12th, 2004 12:25 PM #15
Additional info. Oftentimes blowby is caused by defective PCV (Positive Crankcase Ventilation) valve. Check the valve first before you decide to overhaul your engine. THis is the usual cause of blowby wherein blowby gases tend to find other outlets to escape the engine. For additional info on PCV visit this url:
http://www.autotune.com/cprotest/cpc8c.html
July 12th, 2004 12:50 PM #16
Jim,
Apa unay metten! Nakalalaing kayo! Naimbag man ta adda itti kastoy nga forum!
Nagadon ti naadal ko!
Translation: This website is COOL!
Ciao!
July 12th, 2004 02:18 PM #17
hahahahahaha ok ah! nalalaing amin ti addattoy!!! naimbag nga aldaw mo :-)
