Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Jul 2006
    Yung bagong-bago na Honda daw e hindi pa pwede iakyat ng Baguio kasi nasa 200+ palang mileage. ma pupuwersa daw. tama po ba ito?
    kasi nagtaka ako bakit hindi pwede. e mas masarap nga i byahe yun.
    inputs naman mga guru. TIA
    that's bool sh1t
    Aug 2005
    Puwede kung kaya mong ma limit ang rev mo ng less than 3K.
    Although for some, recommend nila ang "soft" break in - follow the manufacturer recommendations. Iba namana ay "hard" break in. I hataw to 80% (yata) of the RPM.
    Aug 2007
    kalokohan yan, ihataw mo.. yung tito ko nakabili dati ng brand new na fx dinala agad namin sa bicol..
    Dec 2007
    Drive it like you normally would.
    Medyo conflicting ang bali-balita sa break-in procedures. Some people will recommend you extend the engine as much as you can because this will supposedly reinforce the piston rings and reduce the incidence of blow-by later on.
    I've had friends who just drove in their usual manner after getting their cars. No problems to speak of naman afterward.
    Most modern engines don't need a gentle break-in procedure. If anything they've already been broken-in at the factory, usually...or so I've heard.
    kalokohan!!! just drive it to Baguio or anywhere you want for that matter, and if any issue come up, then claim it under warranty!!!
    talaga po mga sirs? kahit more than 100kph ang takbo? para kseng boring kung maintain ko sya ng 70 or 80kph e,hehehe. what time p kaya ako makarating ng baguio nun,hehehe. sabi kse sa service dept. ng honda * least daw nasa 500 na mileage nya para maitakbo ko ng 100kph. e. ngek!
    Yup hataw layk hell repapip. hehehe. Joking aside, drive like you normally would lex. Pwde na ngang dalhin hanggang aparri yan. . . .
    Oct 2007
    sir, pagka-dealiver palng sa casa galing sa planta break-in na po yan. gagawin mo nalang subukan mo lakas niya. yun lang. mga 3-3.5k lang bro oks na yun pwede mo i-long distance yan basta maintain mo lang ang speed.
    yung isang casa(HONDA) dito sa QC eh galing pa sa ibang casa sa probinsya hinahataw hataw daw nila lalo na kung FD sarap daw hatawin sabi ng casa delivery boy papunta dito sa manila.para daw matest kung may factory defect..ganun pala yun.
    Oct 2007
    Aba eh isauli mo yan, ano silbi nyan kung hindi pala puede ilayo sa bahay mo yan.
    sensy
    Quote Originally Posted by EGcoolmhan View Post
    sensya na sir ha... wat do you mean by 3-3.5k?
    Quote Originally Posted by mark_t View Post
    hahaha! dehins na pwede isoli sir... just wanted to be sure lang.
    hirap e kung sa baguio ako abutan... layo nun.
    Jan 2008
    naka break-in na ang vehicles bago pa dalhin sa casa.
    Jan 2008
    Sige po ihataw nyo agad balitaan nyo na lang kami kung tostado na ang engine nyo
    Biro lng po. A lot these days break-in their car the 'MotoMan way' http://www.mototuneusa.com/break_in_secrets.htm with no adverse effect naman daw.
    Pero under warranty pa po car nyo, mahirap na. But it is really tempting, at ang hirap siguro mag-drive ng para ka ng matanda. Ilang buwan kaya bibilangin before maihataw yang honda mo with the traditional break-in method.
    Kung long distance ka palagi, follow the manufacturers recommendation na lang siguro. Daya-dayain mo lang ng konte, 200km/h paminsan minsan.
    Jun 2006
    ok lang ihataw. Na break in na yan sa factory. lagi kong nakikita mga bagong kotse hinahataw sa slex papunta sa dealershp ng mga delivery boys.
    Aug 2005
    Wag mo lang i-over rev. I think ang sinasabi ni EG ay 3K to 3.5K lang dapat ang max rev ng engine mo.
    Nov 2007
    Last December I got my Honda City iDSI CVT. From Honda Alabang after picking-up the unit we went straight to Baguio. I drove the car the normal way. On hi-way I went more than 140kph but never floor the gas. So far my ride is still ok, never got toasted.
    Dec 2007
    Quote Originally Posted by mavsn View Post
    3000-3500 RPM. Engine speed po ito, you measure this with the big tachometer right smack in the middle of your FD's dashboard.
    Every mark there is x1000...so 3000-3500 RPM plays between the numbers 3 and 4 on the tachometer.
    Jul 2006
    I guess what people are saying is you can take it up to Baguio pero keep the engine speed to a minimum and stick to it if and when you can. Personally, hindi ko "hahatawin" in the sense that I rev the heck out of it, a good long drive on the highway is good for the car but the change in engine speed should be gradual, wag mo bibiglain.
    I guess the saying, "When in doubt, don't" holds true here. Depende na sa iyo kung ang tinutukoy eh yung paghataw, or yung pagsunod sa sinabi ng casa.
    Jul 2006
    SALAMAT PO! sa mga nag reply kagad. actually sasakyan ni ma'am mavsn yun. nahihiya magtanong kaya ako pinagawa ng thread. hehehe.
    Quote Originally Posted by Type 100 View Post
    what do you mean by "extend the engine" sir?
    yan nga din sabi ko sir. baka iwas lang sila sa warranty
    makikita mo nga sila sa slex pa ekis-ekis. hehehe
    sabi ko sayo mababait mga tsikoteer e. hehehe. kitam dami kagad tulong at inputs. so ayan kampante ka na. di lang ako may sabi.
Tama ba sabi ng sa service department ng Honda?
