Results 1 to 10 of 10
September 22nd, 2003 04:13 PM #1
HELP...! help
guys i need your expert opinion... my 4D56 TDIC engine.. biglang umingay... as in glig.glig.glig.. parang naging Isuzu engine yung 4d56 ko... dati kasi smooth yung 4d56 ko pag naka idle..
kaninang umaga nung i-start ko siya okay pa naman yung tunog then after 1 min. na naka idle biglang nag iba yung tunog.. ano kaya problema.... Major problem po ba ito or minor lang... please help... anything na ma i suggest nyo.. hu..hu..hu... contact ko na rin mekaniko ko and tiningnan na nya kanina... tiningnan nya ang timing belt and yung tube papuntang air filter okay naman daw... :waah: :waah: suggest nya dalhin na lang sa shop nila para mabaklas lahat kasi kung sa bahay di kumpleto gamit...
help help help... anything na pwede pagsimulan ng tunog ..... hu..hu.hu... does this something to do with the turbo? or air intake problem lang kaya maingay.... help po... im desperate.... :freak:
thanks..
September 22nd, 2003 07:45 PM #2
Pwede pong baka barado ang fuel filter, injectors or problem with the fuel pump. Maganda nga pong ma-check mabuti para maayos. Goodluck. ;)
September 22nd, 2003 08:55 PM #3
Mukhang baradong fuel or air filter iyan kapatid. Try running it without the air filter. Kung wa-epek, get a new fuel filter.
Always start from the basics.
- Jul 2003
- 579
September 22nd, 2003 11:32 PM #4posibleng may tubig or hangin ang injectors/fuel line mo pwede ring valves depende kung ano tunog. I have to hear it first hand. kung mala isuzu ang tunog, possible na valves. kapag maluwag ang piston ganun din pero nawawala iyon after warm up. kailangan marinig. be more specific too. kamusta idle. kamusta takbo?
September 22nd, 2003 11:36 PM #5
Kapag fuel-starved ang makina, malakas ang vibration niyan. Ganun yung sa Benz ko dati. Tapos natetepok kapag idle. Yung fuel filter grabe ang dumi. Contaminated pala yung tank ko. Puro latak at rust flakes.
- Jul 2003
- 579
- Jul 2003
- 63
September 23rd, 2003 10:53 AM #7Looks like barado fuel filter mo............ Papalitan mo na lang....... ang diesel engine pa naman pag kulang ang supply ng krudo naghihikahos talaga :-)
September 23rd, 2003 12:37 PM #8
mga tol,
hindi ko na siya pinatakbo kasi akala ko it has something to do with the belts and engine kaya natakot ako ipatakbo.. nasa shop na siya ngayon and hindi ko pa natawagan kung ano nangyari pero siguro later tatawag sa akin yung may ari.. kaibigan ko kasi... sila din ang kumuha sa bahay...
with regards sa air filter.. have tried wala yung air filter pero no change sa sound... sana nga nasa fuel filter lang ang diperensya...
one click lang naman andar na kaagad yung engine kaya sabi ng mekaniko hindi rin sa timing.. pag idle maingay talaga pero di naman namamatay ang makina..
pag tumawag na kung ano cause post ko lang ..
thanks to all who replied...
September 25th, 2003 05:46 PM #9
Guys,
nakuha ko na ride ko he.hehe. medyo alive na naman ako... inadjust lang daw nila yung timing and some tune up and so far nawala na yung tunog isuzu yehey...
yun lang po..
September 25th, 2003 05:56 PM #10
buti naman ok na..
wag na sana pumalya ulit..
or kung mangyari man..makita na sana yung cause non! :D
