Results 11 to 19 of 19
- Jul 2016
- 44
September 21st, 2016 11:44 PM #11check engine light already resolved po open ko lang un gas cap ko then open close. ok n sya see video.
so far nmn po nun bmiyahe kmi knina calumpit to angeles no tirik temp at 1/4 or near to half
September 22nd, 2016 01:14 AM #12
- Apr 2016
- 130
September 22nd, 2016 02:17 AM #13better to have it checked, kc usually ang check engine light kht mawala yan nag pepersist parin ung problem, I experienced na nag ddownshift ako when i run to tagaytay AT light turned on and CEL also, then pina reset ko ung computer ng car ko then nawala CEL but the problem of downshifting still persist so as soon as i went back to my place dinala ko agad sa mekaniko ko then only to find out that one of my sensor is already malfunctioning. and some bands inside the transmission. so bring it to ur nearest talyer kesa lumala sira lalo na at mukang engine yan
September 22nd, 2016 12:54 PM #14
maybe cam sensor, madalas sakit ng optra but better ps scan mo muna
September 22nd, 2016 01:44 PM #15
Seems like you have a clogged tank breather. The fuel tank is vented into the atmosphere for the fuel pump to suck gasoline.
If said vent is clogged, your fuel pump is restricted. In some cases, gas tanks are known to crumple.
see here:
What happens when a tank vent gets clogged. - PeachParts Mercedes ShopForum
Vent valve, how it works, symptoms, problems, testing
- Aug 2015
- 862
September 22nd, 2016 02:38 PM #16pwede ka talaga mag CEL sa gas cap na hindi maayos pagkaka balik. It is a common trigger, so kung hindi na naulit that might be it. to be extra safe pa scan kung may code.
- Jul 2016
- 44
September 23rd, 2016 11:55 AM #17oo nga eh kasi bos nag pa gas lang ako nagkaganun na. then check ako sa bahay research sa google . un nga gas cap so tinitry ko ayusin. ok na wala ng CEL
thanks sir
ano po ba dapat ko icheck pag bibiyahe ng malayo? this sunday po kasi biyahe kami isabela provice. ? thanks
- Aug 2015
- 862
September 23rd, 2016 12:32 PM #18
- Jul 2016
- 44
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
