Nung nagpark ako sa garahe, sabi ni misis medyo mahapdi sa mata ang gasolina na galing sa auto ko. Is there something wrong with my car's engine?
My ride is a '95 Mitsubishi Lancer GLXi (itlog w/ 4G92), the fuel that I'm using is Shell V-Power. The car was bought recently, sabi ng first owner, newly tuned up so I haven't really checked the car's worn out parts like spark plugs and air filter. The odometer reading is 81000+ kilometers.
You can give a quick check (or sniff) around the car to see where the smell of gasoline is strongest. Then with the car idling, check under the car for signs of dripping fuel.
If the smell is coming from the engine bay, check along the fuel line and the engine itself. Among other places, check the sparkplugs if they are wet.
Check if fuel is leaking from the hoses and metal fuel lines. Ethanol in E10 gasoline can erode metal fuel lines and also prematurely harden rubber fuel hoses.
