Results 661 to 670 of 1166
August 23rd, 2020 10:11 PM #661
Fuel consumption ko before consistent 6.9 to 7.2km/L, at average 18km/h. Ngayon di bumababa nasa 7.5 to 7.7km/L, same average 18km/h. It is worth noting that I also replaced the 1 year old air filter though. Medyo marumi na, hindi na lumulusot ang ilaw.
Yung singaw ng engine bay, wala ako nung thermometer na baril eh. But I always open the engine bay after a long hard drive since there a few ecoboost owners who seem to have coolant loss due to the engine block cracking supposedly because of heatsoak. It’s usually uncomfortably hot but now the heat emanating from it is quite tolerable. But as you said, baka placebo effect lang nga since I really can’t provide any numbers when it comes to engine temperature. But the fuel consumption is a real noticeable improvement though.
August 23rd, 2020 10:17 PM #662
Yun nga rin naisip ko but it’s there. I didn’t touch the cooling system. Yun lang ginawa ko. The engine bay feels less hot when opened. Placebo effect or maybe timing lang? Possible. But that’s just something I personally felt and noticed. I really was expecting it na sumingaw ng sobrang init tulad ng dati since as far as I know, wala naman kinalaman ang oil sa pag cool ng engines.
- Dec 2013
- 521
August 27th, 2020 05:41 PM #663Actually nakakatulong ang good engine oil sa lesser heat generation pero hindi solely nakasalalay doon, a good engine oil makes engine parts cause less friction with each other, when there is less friction then less heat generation then also you got to consider if the lesser friction then the engine would operate more smoothly with exerting too much gas/diesel being injected sa kada cylinder, overall the vehicle will operate a lot more smoothly.
- Dec 2013
- 521
August 27th, 2020 05:46 PM #664Aisin is related to Toyota pero the aftermarket products are not the same with Toyota anymore, they decided to outsourced almost everything for the aftermarket. First of all Aisin doesn't even produce lubricants and filters, the "Aisin aftermarket" is a different division na as they are solely doing aftermarket products by trying to outsourced their products from different China factories then packing it under the Aisin brand name. The clutch disc and pressure plate are the only products for the aftermarket that are being produced by Aisin's own factories, the rest of the aftermarket products are outsourced even the brake pads.
August 27th, 2020 05:54 PM #665
During Engine testing & validation they use their recommended oils ...fulll power testing ...yes pls.
- Jul 2009
- 2,618
August 28th, 2020 02:08 AM #666
August 29th, 2020 11:13 PM #667
September 13th, 2020 02:57 PM #668
im looking for an alternative oil filter and im choosing between baldwin, wix and js asakashi.
car is 1997 honda civic. currently installed is vic 809.
sa lazada ako tumitingin.
baldwin 1402 is at 400+.
js c809j ranges from 180 to 300.
wix i have no idea anong compatible sa oto ko. anyone?
if ever i'll go with JS if wala ako mahanap na wix counterpart.
September 13th, 2020 11:28 PM #669
Baldwin, wix or Purolator if may mahanap ka. Amsoil and Mobil filters baka meron din.
Bosch then Vic next level down.
Sakura at JS naman if wala pa din talaga.
For oil go with the recommended viscosity and API rating. Synthetic if matagalan palit like me na 1yr or if 6months or less or 5K whichever is earlier eh pwede na mineral oil para cheaper.
Sent from my SM-N960F/DS using TapatalkFasten your seatbelt! Or else... Driven To Thrill!
BANNED BANNED BANNED
- Sep 2015
- 13,919
September 13th, 2020 11:46 PM #670basic yan B1402. Mahal kung 400+
punta ka sa araneta avenue yung sa guirayan street meron doon nagbebenta baldwin at fleetguard (cummins)
Meron yung ginagamit nya sa heavy duty eh ginagamit sa BRZ at yung pinsan nya naka toyota 86. Same fit din sa honda civic kasi dati ganyan kotse ko vti
Nalimutan ko yung code pero puntahan mo. May advertisement yun sa carousell
