Results 1,131 to 1,140 of 1166
- Feb 2014
- 2,536
April 4th, 2023 12:23 PM #1131
update! dumating na yung 7131. as expected it's longer but the threaded part isn't recessed like on the 7119
so probably not safe to substitute
April 4th, 2023 04:06 PM #1132
Para sa anong sasakyan?
Sent from my CPH1911 using Tsikot Forums mobile app
- Sep 2021
- 758
April 4th, 2023 04:38 PM #1133If you want to experiment with alternative filters...
--- > maybe it would be a good idea to have a stock one, or one that you're sure will work properly in reserve in the car, just in case?
--- > I don't know if its possible, but a poorly fitting one may not leak (yet) in the garage, but spring a leak later down the road (kasi under pressure/load na). Imagine realizing you're losing oil pala and nasa malayo kang lugar...
April 4th, 2023 06:58 PM #1134
Baka mahaba masyado bolt at sumayad. Pwede naman itry.
Sa 4m40 Pajero ko I tried BD28 and hindi pwede kasi may sumasabit sa loob. Mahaba yung bolt ng 4M40 kaya BD7028 talaga. Unlike sa 4d56T na Strada na pwede kahit BD28 or BD7028.
Sa case mo baka ganun din, mukhang mahab bolt niyan kasi recessed yung sa 7119, baka sumabit yung 7131.
Pero try mo lang muna. Kapag pumasok at mahigpitan, okay yan.
April 11th, 2023 10:46 AM #1135
There seems to be a lack of supply of Motul engine oils. I already inquired at 3 car maintenance shops and they all said there's no Motul.
April 11th, 2023 02:46 PM #1136
I got the chance to talk to a nearby car mechanic shop. Another distributor snitched the Motul supply from Autoplus.
April 12th, 2023 07:02 PM #1137
Bakit madami nagbebenta sa Lazada?
Sent from my JEF-NX9 using Tsikot Forums mobile app
April 12th, 2023 07:32 PM #1138
not oil filter related, but has anyone tried installing a neodymium magnet disc on the drain plug or istalled a magnet around the externally installed oil filter? similar to the rear wheel drive differential drain plug, there is a magnetic tip on it to hold and prevent the ferrous particles from moving around
April 12th, 2023 07:44 PM #1139
April 12th, 2023 07:49 PM #1140
the neodymium disc magnet has low profile and comes in sizes that is the same diameter as the tip of the drain plug. neodymium magnets are very strong and can hold more particles. on outboard mounted filters, i use a magnetic strip similar to those found on refrigerator door magnetic seal. i staple both ends once fitted around the circumference of the filter housing
