Results 1 to 14 of 14
    Apr 2008
    Hello im new at Tsikot.com. Since you guys know alot about cars and Manila, can anyone recommend a shop or garage with a good port & polish mechanic? Its for a Ford lynx ZMD 1.6 dohc or b6? for mazda cars. I am for quality works with no compromization. Salamat po.
    Dec 2007
    Quote Originally Posted by paullex View Post
    black sheep autoworks...eto po # nila 2400092 sila po ang mga kumakarera dati sa marcos highway ngayon puro track racing na sila at legal racing...
    san sila located? proven and tested na po ba sila?
    Oct 2007
    sir try mo sa KANZAI performance dito sa may araneta ave. recommended ng mga HCP'ers. di ko sure bro kung pwede yung tsikot mo dun kasi puro honda engine ginagawa nila dun. tested ko narin.ok naman!
    *EG,
    Contact numbers post ka naman,
    *Force,
    Dude, have called them up and for my ride, they have estimated the billed about 20-25k, all in na ang items sa kanila.. regarding P&P yan ha,
    Located cla sa:
    Black Sheep - Look for toochie
    Imelda Ave, Cainta RIzal. 2kms rightside.
    Anu ba tlga ang advantage pag nagpaP&P ka? and bkt ganun kamahal?
    Aug 2004
    Before you go into port & polishing, consider the engine itself. Port & polishing will only work if the rest of the engine, the intake manifold, the valves, the intake and exhaust modifications, etcetera, can flow enough to maximize your gains. My advice? Before doing this, research on the internet. Find out all you can about your engine, and where the possible restrictions are, before commiting to this. You might also find advice on what part of the cylinder head it is best to concentrate on when P&Ping.
    20-25k is about average. You can also try ATi (located on the road going to Tagaytay from Santa Rosa)... they test their work on a flow-bench to ensure even cylinder-to-cylinder flow.
    There are also a couple of others. There's Bernard (don't know his shop), who was recommended to me by Speedlab, and also the main man at AutoPlus, Pacho... they're pricier, but they take their time and study the engines they're P&Ping.
    Still, nothing is sure... and you sometimes run the risk of P&Ping too much, which will make your engine sluggish down low.
    Also consider engine management. If your stock computer cannot handle the extra flow properly, you will not maximize gains, either.
    For the threadstarter... join up at http://forum.fordclubph.com to find out more about your engine and what you can do to maximize its potential.
    Apr 2008
    Thank you guys for your great suggestions! Ive been reading other forums too and i keep hearing Black Sheep is the best for my ZM engine.
    I am not striving for looks but speed, not the commercialized tuner market car, but my own tuned speed bred toy car, so i try to experience the possibilies of what it takes to create/build one(affordably).
    I am a professional race driver localy and Int'l. I do have experience with competivive motorsport but what i am trying to do is see things on the other side, the tuner world they say, and try to produce a tuner with whats available around. It is not a prof. race car where there are rules to follow(engine blueprinting, minimum weight), and specially its not for racing on the streets.
    Right now the car has a full intake power flow sys, 421 headers, 2.5"pipe, reso, power flow muff the full IHE and is bieng stripped of heavy parts in replacement of lighter materials (thnx to pr), lower and stiffend frame.
    I just want to clear that its not for street racing! i just drive fast, logicaly...
    I hope you guys can help me by giving suggestions of places and garages to get parts and accessories wiht my questions in the future. In the end i do want to share the knowledge i will get from this to everyone. Thanks again in advance!
    *niky
    where exactly is ATi? is it after paseo, in the middle of the climb to tagaytay? i live quite close thnx!
    Oct 2007
    Quote Originally Posted by mackkcam View Post
    *EG,
    *Force,
    Located cla sa:
    mack,
    kanzai performance
    landline: 482-2557
    look for mike: cp # 0917-5371677
    Aug 2004
    *niky
    Hehehe... I live close to there, too.
    Yup. After Paseo. Not very far up... you'll see it on the right side after one or two villages... if you get to the PNP Camp, you're waaaaay too far up, already.
    Again, join our boards, ( http://forum.fordclubph.com ) lots of guys looking for power solutions for the ZM. Last I recall, with a full intake, header and exhaust set-up, the highest I've seen is just 95 whp. Stock makes a measly 80 whp. But the header in question isn't so good... doesn't make much top-end. There's talk that the motor is good for turbo, due to the stout bottom end, but not many locals have done it on the 1.6 (none that we know of).
    We have yet to get a member dedicated enough to go for engine management on the 1.6... and we'd like to see the results. It's 30k pesos for the Unichip, and usually, it gives 10-15 hp gains in the midrange and 5-10 hp gains up top for small gasoline engines, depending on the engine and mods.
    But if you're set on PnP... get that first, then look on http://www.mazdas247.com/forum/ for advice about cams for the engine (for them, it's the Mazda Protege...), then once you're done with everything, THEN get engine management.
    I'm betting it's possible to get 110-120 whp out of the engine... which would be equivalent to 140-150 bhp, with a port n' polish, cams and the ECU. Not blisteringly fast, but fun enough.
    Apr 2008
    Thanks Niky! Yeah i ddnt think the hp by the wheels would be that low, quite dissapointing, but that means more work!
    Il try to get a dyno test by next week and see how it fares out but for the mean time, where do you get reliable performace parts, specially clutch assembly?
    how do i get my hands on those infamous unichips?
    I will give Ati a visit tmrw if not this week, ill see what they see..
    Im game to prep a 1.6 zm since its what i have atm, tho i dont think turbos quite fits the job, force induced are for drivers who wants power the easy way, i love the raw sound of a speed bred n/a engine, reminds me of formula cars, on road.
    What do you guys think of a rebored engine?
    Aug 2004
    Re-bore... hmmm... I don't know. Depends on the block. Most you could probably do is gain about 0.05 liters... not really worth it unless you're prepping the engine and putting in high-comp pistons at the same time.
    I know what you mean. I've ridden/driven cars much faster than mine, but I still want to keep that NA sound.
    The Unichip is at Speedlab, Quezon Avenue. They do installation and dynotuning in-shop. If they're not familiar with the car, wiring the chip will take two or three days. But it's worth it. Speedlab is at Quezon Avenue... phone number: 376-4648
    ATI can also give suggestions for build stuff... pistons and rods to use if you're working on the short block, etcetera... but remember, research on the engine thoroughly before committing. You can also try clubprotege.com and protegefaq.net for more info.
    For parts, there are a bunch of guys on fordclub who can hook you up with suspension parts, intake parts and exhaust. For exhaust, I suggest you go custom, though... but take the deals on intake tubing (Simota... available... cheap) then fit it with a K&N. Watch the MAF placement, though... if the filter is too close to the MAF, you lose power as air turbulence plays havoc with the MAF.
    Good luck!
    Sep 2006
    dollar/horsepoewer turbo is the way to go.Porting and polishing is a waste of money.
    You claim to be a "professional race driver" locally and internationally therefore you should know speed costs money right. A rebored 1.6l engine with mods might only be as fast as a stock 2.0l. A forced induced dohc 2.0l up engine will have the speed you are looking for.
    Apr 2008
    Quote Originally Posted by Si 06 View Post
    Lol stumbled on this thread again
    * Si 06 I race professionally when I wrote this thread. I had FIA race licence with AAP for karting and race across Asia, along side with Marlon and Matteo.
    As for my 1.6 ZM-DE. I was able to rebore to .50 along with handful tuning upgrades, few years back with the ATI guys!
    I still drive this car and is now a track-car. Good times
Best Port & Polish mechanic.
