Results 91 to 100 of 136
February 27th, 2012 11:27 PM #91
GTOil no need to change oil ever. The only one with alien technology dissolves dirt and sludge but not the paper filter of your car.
February 28th, 2012 08:01 AM #92
right now im using bardahl fully synthetic... but im also distributing gulf,zic, and mobil oils... personally it all boils down to personal preference and trust on the brand... but most oils will perform granting they are able to provide Product Data Sheet so you'll know whats in the oil your using...
Among the local brands only petron doesn't publish their technicals and data regarding their oils! delo of caltex and shell lubricants has their Data sheet published in the internet... i wonder why petron is shy telling the public whats in their oils...
March 16th, 2012 12:50 PM #93
ask ko lang which is better para sa carens ko-- crdi-vgt.
HKS?, royal purple, liquimoly, motul?? etc...
ung kahit paano makakabawas sa tunog ng makina.. feeling ko maingay parin, except kung may katabi kong old-school diesel... pero pag sa garahe, dinig ko... or sadyang sanay lang ako sa refined gasoline engine..
manual dictates na 10w40, 15w40 is recommended..
March 16th, 2012 02:43 PM #94
you should also check the API rating. alam ko CI-4 above na kasi requirement sa crdi e.
im currently using Top1 SDO in all of our diesel rigs and trucks. CI-4 and 15w40. it was also posted in the other thread that this oil is a good quality semi-syn oil (i'll try to look for the link). cost less than 300pesos/quart.
pero if you will stick with your choices,
1st/2nd liquimoly/royal purple (whichever is more accesible)
3rd motul
4th hks
March 16th, 2012 03:31 PM #95
For the past 3 pms, Castrol parati yung ginagamit ko. Performance, ok naman. Wanted to try Royal Purple or Motul sana kaya lang mahal. Hehe. Na-try ko na rin yung Top 1 dati.
March 18th, 2012 01:34 AM #96
I just bought an Idemitsu EcoTec 5w30 engine oil. So far so good. PHP1300, 1 gallon na.
March 18th, 2012 07:31 AM #97
zic power diesel synthetic 10w40... cheap lang... i bought it for only 3200 pesos 20liters can.... or 160 pesos lang per liter....
mas maganda sa caltex, castrol, mobil non synthetic, top one diesel synthetic, valvoline none synthetic, shell oils except the synthetic shell oil hindi ko pa kasi na subukan...
March 18th, 2012 12:07 PM #98
March 18th, 2012 12:13 PM #99
I'm using the same oil sir, sa Unioil po nabibili yan. Sila ang distributor. Fully Synthetic po sya.
March 18th, 2012 09:05 PM #100
pag gas engine kasi hindi masyado need na robust ang oil to used.. a good semi synthetic will do, but if you're after longevity and maximum performance try to use an oil with CI-4 rating together with an SL API rating...
Good amount of Phosphorus/calcium/moly/boron and a very good TBN reserve..
traditional gas engine oil (SM/SN) will only have 6-8 TBN rating whereas CI-4 with SL rating will have TBN of 9-10...
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
