Results 1 to 9 of 9
- Feb 2008
- 577
- Jan 2009
- 5
February 3rd, 2009 10:21 PM #2I haven't seen it locally but it has an excellent reputation as a Group III oil. Someone at BITOG says it's similar if not identical to Shell Helix Ultra. Pennzoil btw is owned by Shell (SOPUS - Shell Oil Products US).
BANNED BANNED BANNED
- Nov 2008
- 1,383
February 4th, 2009 02:23 AM #3
- Jan 2009
- 5
February 4th, 2009 10:32 AM #499.9% of cars on the road don't need Group IV or V based oil either. Any SL or SM rated oil would be more than enough protection (at the right viscosity). Unless you were a dedicated track driver or drive a hot running turbo engine, PAO or ester-based synthetics would be a waste of money too.
Also, some Group III based oil products do outperform some Group IV or V synthetics based on used oil analysis (UOA). Base stocks are only part of the overall package, the additives that the manufacturer uses are critical too.
I would choose the P590/L Shell Helix Ultra anytime over the P900/L Group V I used to run in my 184 HP engine. I'll go back to Group IV or V synthetics only if I had a Skyline or WRX STi.
- Nov 2008
- 1,383
February 4th, 2009 01:46 PM #5So you admit that Group IV and V are the better performing oil. Because you will use it on the better cars.
Shell shouldn't be charging P590/li for modified mineral oil. Mineral-oil base stocks sell for just P55 Pesos per liter wholesale in Bataan. The big 3 oil companies source it from there. Then they start adding their own additives.
Group IV and V Synthetics are built up molecule by molecule. They are not petroleum-based therefore are TRUE synthetics.
NASA specifies Group IV (PAO) synthetic in their space vehicles. That says a lot.
- Jan 2009
- 5
February 4th, 2009 04:28 PM #6There's no question that Group IV or V base stocks:
- shear less at sustained high-temp high-rpm driving
- oxidize less at very high temps (>150°C)
- flow better at very low temps (<20°C)
The question is whether your average daily-driven car needs such protection. Even a Group III oil is overkill for most cars.
Sure NASA specs Group IV, but our cars obviously don't go through the conditions and temp ranges that the space shuttle does (-90°C at the mesosphere and >1,000°C at the thermosphere). If Honda wanted to use materials and fluids used by NASA, the everyday Civic would probably cost more than P50 million.
Would you use titanium alloys for your frame just because it's stronger and lighter than steel? No, because steel does the job at the right price. Would I put Yokohama ADVAN Neovas on a Vios? No, because it won't see the track. Same with oil, you don't need high-end expensive oil to protect almost all of the engines out there.
Choose oil at the right viscosity, with an API SL or SM rating for gasoline engines, CH-4 or CI-4 for diesel engines, or ACEA A3/B3 or A3/B4 for Euro cars. Mineral or synthetic, for most engines it doesn't really matter as long as you change the oil and filter regularly.
- Feb 2008
- 577
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 15th, 2009 11:38 AM #8in the end, it's what value for money you get. pay a lot more for the local group III oils or less for better quality group IV oils... not much of a question imo.
- Feb 2019
- 6
Thank you!
