Results 31 to 36 of 36
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 22nd, 2009 03:43 PM #31if you want to minimize the chances of leaking you can use the 20w50 full syn oil. if bago bago pa yung seals you can use 10w40.
July 22nd, 2009 05:00 PM #32
meron bang oil filter ang speedyfix pang kia rio 2008 model? im having my 1st change oil mag 7,5k na kasi ako...
- Nov 2003
- 3,849
July 22nd, 2009 10:35 PM #33we'll need to see what size it uses before i can say for sure. or you can bring your own filter din para sure.
- Mar 2009
- 64
July 23rd, 2009 09:37 AM #34
Eh Sir Speedyfix, ano po un sinasabi ni Voltscastillo na hindi daw po maganda yung 20w50 na oil? And magkano po ba change ng seals if ever lang kailangan na palitan?
Anyways, mas alam nyo naman po siguro ang the best for the car pag dinala na sa shop nyo.
My another concern is every time na nagpapachange oil ako is pinapalitan na din po yung spark plugs, if nagpa-synthetic po ako and kung 10,000kms pa before I change the oil again, how do i know if i need to change the spark plugs na? Thanks!
- Mar 2009
- 64
July 26th, 2009 09:57 AM #35I've had the Oil changed na po last Saturday sa Speedyfix, royal purple 10w40 po yung nilagay then pinalitan po yung 'rubber seal' na worth 50php nakalimutan ko po kung ano po tawag hehe. Pinalitan na din po yung sparkplugs.
So far so good po. Thanks Sir Speedyfix!
- Nov 2003
- 3,849
July 26th, 2009 10:07 AM #36the plugs will last 10k kms without any problems. the seals naman will depends ano yung tumulo. minsan simple lang and mura yung fix, minsan mas mahal. it's always better to use the thinner oil, but some opt for the thicker one coz they don't want to deal with the leaks.
nice&clean, thanks too!
Daming issue ng SU7:grin:
Xiaomi E-Car
