Results 1 to 10 of 12
October 19th, 2008 07:39 PM #1
mga sirs, tanong ko lang po
kasi kapag "i-on" ko na yung auto ko,
dati meron ako naririnig na sound sa front right part ng engine bay.
parang "grrrrrrrrrrrr" which tingin ko gumagana yung fuel pump.
ngayon wala na pong syang sound, pero nakakpag start pa rin
yung sasakyan.
anu kaya problema nun? or meron po bang problema kapag ganun.?
thank you very much po sa inputs
October 19th, 2008 09:06 PM #2
kasi pag may sira po sir dapat ilaw ung check engine po... observahan po muna
October 25th, 2008 02:30 AM #3
Anu car ito? Gas o diesel? madalas ang fuel pump nasa likod near the gas tank except for those mechanical na nakakabit sa engine.
- Nov 2004
- 141
October 26th, 2008 08:53 AM #4sa computer ang problema niyan. sa older cars usually nag leak na capacitors sa computer. kung DIYer ka, palitan mo na lang ang caps. kapag dinala mo sa casa iyan, isa lang ang sasabihin sa iyo, "palitan natin ang computer"
pero ok lang naman yan, minsan mahirap lang mag start sa umaga kasi hindi primed ang fuel lines. tatakbo pa rin auto mo.
October 27th, 2008 11:09 PM #5
corolla gli po
dati kasi hinihintay ko umandar yung "grrrrrrrrrrrrr" sound nya before starting.
pero kapag yung sister ko yung gumamit, diretso click na agad
kaya ayun nawala na lang bigla yung "grrrrrrrrrrr" sound nya.
computer box ba? ang location ng capacitor?
October 28th, 2008 03:08 PM #6
The "grrrrr" sound is the fuel pump initializing and pressurizing the tank.
Yung capacitor ay parang maliliit na baterya (yung Eveready) sa computer box. Usually over time, they leak, kaya nasisira. Pero in your case, I doubt kung comp. box ang sira.
Pa-check mo yung fuel pump, malamang nasa ilalim lang ito ng rear seats. An auto electrician knows how to check kung gumagana pa to. (Pero since sabi mo, nagsa-start pa rin, malamang ayos pa rin ang fuel pump. Kung sira kasi, di na yun tutuloy, puro redondo na lang).
October 30th, 2008 11:51 PM #7
gets ko na sir, pero yung fueld pump ko ata nasa harap ng engine bay eh dun ko sya naririnig dati wala sya sa rear seats. ty po sa info sir
October 31st, 2008 12:45 PM #8
are you sure nasa harap ang fuel pump ng Corolla GLi? somebody correct me if I'm wrong pero ang alam ko kasi nasa likod yun eh
baka hindi priming ng pump yung nadidinig mo, baka sa ibang part yan.
- Jul 2009
- 2
July 28th, 2009 12:42 PM #9Mga Sirs, baka po pwede po mag tanong?
Nag change po ako ng fuel pump 98 Sonoma. Nung una, tumatakbo ng maayos tapos after 3 weeks pag uminit na po yung sasakyan, ng mga 20 minutes, namamatay ang makina na parang di kumukuha ng gas.
Once it cools off, ok na naman po cya, it runs ok again, until yun nga po, uminit ulit, namamatay po talaga.
Advice naman po.
July 30th, 2009 09:38 AM #10
Naku, ignition coil yan. Sigurado ako, 100%. That happened recently to my 97 Accord. Akala ko nung una, main relay. Eh namamatay pa rin yung engine pag mainit na. After it cools off (around 15 minutes or so), puwede na ulit siyang i-start. Pag minalas ako, pag uminit ulit, patay ulit. Laking perwisyo talaga.
Somebody suggested na ignition coil daw. So I bought one (Japan replacement, not OEM). Nung pinalitan ko na, ok na. Di na ako tinirik ulit.
Hindi ko kabisado ang Sonoma, pero malamang, nasa loob din ng distributor yung ignition coil niya. Yung mga lumang kotse kasi, external na ang distributor.
Okay that would be easy I thought coolant and distilled water cant be mix and Honda coolant is...
2019 Honda Brio
