Results 21 to 30 of 34
- Apr 2013
- 1
April 13th, 2013 04:38 PM #21Oil Base Stocks
Oil base stocks are divided into five general categories, as defined by the American Petroleum Institute (API):
Group I - Conventional - Mineral oil derived from crude oil
Group II - Hydroprocessed - Highly refined mineral oil
Group III – Severe hydroprocessed
Group IV – Polyalphaolefins (PAO)
Group V - Other base stocks not included in Group I, II, III, or IV (e.g. ester-based oil )
Kabilang sa group III to V ang synthetic..kayo na po ang bahalang mag-aral kasi ako kuntento na ko sa ginagamit kong fully synthetic oil kung ano iyon check niyo na lang ang facebook fanpage nila or website; www.s-oil.com.ph /facebook.com/s-oil phillippines.
- Sep 2012
- 194
April 14th, 2013 11:53 AM #22question po, kung pangit or hindi compatible yung engine oil na nailagay sa makina, mararamdaman ba instantly ang effect ito?
after ng 10k pms kasi ng pick up ko (changed oil and oil filter, cleaned air filter element, nothing else), ang laki ng binaba ng performance, sa feeling gauge lang, pero i am driving only this pick up so i have a strong feel of how it runs before the change oil and ang tamlay manakbo after the pms.
hindi naman mausok.
my unit: 2013 2.2 ranger xlt m/t
engine oil they (casa) used: 8 liters castrol 5w-30 (daw), came from a drum daw since hinihingi ko yung container, sabi sa drum daw galing.
thanks...
April 14th, 2013 01:56 PM #23
- Jan 2010
- 367
April 14th, 2013 02:19 PM #24hello sir, 5w-30 is malabnaw na nga for a diesel engine, dapat mas magaan ang pakiramdam ng makina mo kung wala naman ibang problema. As far as I know, I also have a diesel engine SUV, originally from casa oil na 15w-50, i shifted to 15w-40 which is also recommended from the car's manual, ramdam agad yung pino ng andar ng makina and very smooth ang acceleration and pulling power. Check mo na lang yung car's manual mo and maybe have it checked by your casa dealer....JM2C
- Sep 2012
- 194
April 14th, 2013 02:21 PM #25
April 14th, 2013 03:44 PM #26
- Sep 2012
- 194
April 15th, 2013 01:17 AM #27ito nakalagay sa owner's manual ng unit ko...
* Initial fill is European oil WSS-M2C-913-C in all plants. For high sulphur markets change
engine oil at first service interval to WSS-M2C-921-A.
Your engine has been designed to be used with Castrol and Ford Engine Oil, which gives
a fuel economy benefit whilst maintaining the durability of your engine.
Engine oil - Diesel (for markets with low sulphur content less than 350 ppm): If
you are unable to find an oil that meets the specification defined by WSS-M2C913-C,
you must use SAE 5W-30 (preferred), SAE 5W-40 or SAE 10W-40 that meets the
specification defined by either ACEA A5/B5 (preferred) or ACEA A3/B3.
Engine oil - Diesel (for markets with high sulphur content greater than 350 ppm):
If you are unable to find an oil that meets the specification defined by WSS-M2C921-A,
you must use SAE 10W-30 (preferred), SAE 5W-40 or SAE 10W-40 that meets the
specification defined by either ACEA E5-99 or API CH-4 or higher.
kung low sulphur content ang diesel na gagamitin, preferred ang 5w30,
kung high sulphur content and diesel na gagamitin, preferred and 10w30...
i guess they should used a 10w30 engine oil? at dapat full synthetic since change oil interval is every 10kms...
baka nga mineral oil nilagay? kaya pangit andar ng makina ko.
btw, i checked the oil dipstick and oil is a little above max level (cold engine / leveled parking), kung ibase natin dito nasubrahan pala nila oil kahit 8 liters lang nilagay (8.6 liters as per manual), double check ko level later. hopefully my problem is just overfilled engine oil.
- Sep 2012
- 194
April 15th, 2013 09:10 PM #28confirmed, it was too much engine oil. hindi dahil sobra ang refill, kundi dahil kulang ang pagdrain sa initial oil... we had to drain around 1.3 liters of the oil to put the engine oil level below the max mark of the dipstick... new oil was already black in color after just around 150km.
April 15th, 2013 10:03 PM #29
focus on the viscosity rating like API & SAE rather than the oil type
for insightful understanding of SAE multigrade rating go to bizol.com then click the "viscosity comparison" to see the difference with the different viscosity ratingsLast edited by kisshmet; April 15th, 2013 at 10:09 PM.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
