Page 9 of 12 FirstFirst ... 56789101112 LastLast
Results 81 to 90 of 116
  1. utopia45 Guest
    #81
    Sir Auto_Xer,
    Is the 20w-50 oil icon is using on his accord before mineral, semi, or synthetic? Thanx.
    #82
    mobil delvac
    #83
    utopia45,
    It's semi-synthetic, it's the same oil we use on our past turbo rallye car & current NA rallye/x car, as well as our other vehicles.
    #84
    Castrol
    I believe it's synthetic...
    Dec 2002
    #85
    1) Mobil 1 full synth for gas engines (5w50 and 0w40 available locally, i've also used 15w50 tri-synth from US)
    Tried LiquiMoly 5w40 full synth- got good mileage.
    2) Mobil Delvac 1 full synth for diesels- 5w40- the best full synth for diesels AND gas too! API rating CI4, CH4, SL, SJ.
    Jan 1970
    #86
    I am currently using Mobil 1 with SuperSyn 0W-40 API SL (from the U.S.) for the Mazda 323 Familia 1.6L, Corolla 1.6L 4A-FE, and Adventure 2.0G. No complaints, very easy on starting, and very little consumption in-between oil changes. Several notches superior to Mobil 1 tri-synthetic formulation. If you have access, go for it.
    Dec 2002
    #87
    ondoy,
    Just got mobil 1 supersyn 10w30 from US. Will use it on honda CRV.
    How much is the mobil 1 0w40 in the US? What's the landed cost in the Phil?
    Jan 1970
    #88
    jackaroo,
    Sent you a PM.
    Apr 2005
    #89
    I only use mobil 1 on my 1998 elantra. the best fully synthetic engine oil.
    #90
    Revive ko lang po yun thread na ito. Sa panahon ngayon anu ang magandang oil na gamitin, yun malaki matutulong sa fuel consumption at performance ng kotse? mag-chachange oil na kasi ako in a few weeks. I'm using a Hyundai Sonata 2000 GLS pala
Ano pong ok na Engine Oil? Survey na din, ano oil nyo?
