Results 91 to 100 of 116
September 20th, 2006 08:50 PM #91
shell helix semi-syn for gasoline
shell helix full-syn
shell helix
shell rimula-x for diesel
since i started driving in 1986, i've been using the above.
- Mar 2006
- 58
September 20th, 2006 09:52 PM #92
September 21st, 2006 08:34 AM #93
- Nov 2002
- 194
September 21st, 2006 12:45 PM #94shell helix (blue) semi-synth 10w/40 or castrol gtx 20w/50 pag budget
- Mar 2006
- 58
September 21st, 2006 02:32 PM #95anu po ba current prices nila? yun sa Castrol at Shell Helix (full synth/semi-synth)?
Ito po ba lahat ng Shell Oils na available?
http://www.shell.com/home/Framework?...ga_0312.html#0
September 22nd, 2006 12:27 PM #96
Current Price of Castrol Magnatec 10W-40 Semi-Synthetic 4 Liters is P1,100. kakachange lang last tuesday...
we use:
Castrol Magnatec 10W-40 Semi-Synthetic for Toyota 3C-TD
TOP 1 15W-40 Fully-Synthetic for Mitsubishi 4D56-TDI
One oil manufacturer claims that "some people in the industry use multi-viscosity as if it means the same thing as multigrade. An oil cannot be multi-viscosity, but it can be multigrade by meeting the viscosity requirements for SAE 30, 40, 50 or 60 and one of the sub-zero "W" viscosity requirements. At one time, some oil companies labeled oils SAE 10W, 20W30—as if the oil could be 10W and 20W at the same time. This is impossible because 10W is measured at -20 degrees C and 20W is measured at -10 degrees C, which eliminates the multi-viscosity theory."When you see 10W-30 on a quart of oil, it means that it acts like 10 weight oil when it is cold (the "W" means winter, say -10^C), but acts like 30 weight oil when hot (100^C). This is not to say that it is actually thicker when it is hot. Hot 30 weight oil is thinner than cold 10 weight oil. Even so, it still helps provide the benefits of both types of oil depending on its temperature. So 0W-30 oil acts like 0 weight oil when cold, but maintains a 30 weight viscosity when hot.
Read the Labels na lang to make sure your vehicles fit the category...Last edited by rion; September 23rd, 2006 at 03:30 AM. Reason: wrong price...
September 23rd, 2006 01:51 AM #97
guys, tanong lng, yung suki ko kasing mekaniko advised me to just use shell helix super (yellow), my car's 12 yrs old. masama na daw kasi kung gagamit pa ko ng helix plus or ultra. should we really consider the age of the engine in considering whether to use synthetic or mineral? i use helix, yung super kasi(yellow) mineral lng sya.
- Mar 2006
- 58
September 23rd, 2006 05:44 PM #98based po sa website ng Shell:
Helix Yellow nga ang advisable gamitin ng car mo.
September 24th, 2006 12:57 AM #99
my brothers are using motul h-100 10w-40 fully synthetic motor oil. 380php/liter.
September 24th, 2006 02:57 AM #100
i tried using enoc oil on my honda and pansin ko smoother ang idling and acceleration.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
