Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    ano mas maganda na motor oil? yung umiitim or yung di nangingitim?
    oil change time na naman kasi ako. pero yung oil ko di nangitim , di nagbago color.
    does that mean di effective yung oil? or maganda yung oil?
    Dapat mangitim iyan kasi sa kanya kakapit ang impurities. Kaya mo nga siya papalitan dahil saturated na siya.
    Jun 2005
    Quote Originally Posted by gudboy
    your oil is not dark. Your changing your oil to early, not using your vehicle that much or you got a very good seal on your piston ring. It should be dark by at least 1000 or 1500 miles/km, for diesel engine it should be a lot earlier because it contents more sulfur than regular gasoline. But don't use that as gauge in changing your oil, follow your manufacturer's recommended interval.
    naka 5000 na yata kotse ko.
    ginamit ko langis pertua semi synthetic.
    di nangitim kaya nagtataka ako baka di gumagana yung langis
    tama si otep, dapat nangingitim. dahil it shows na nililinis ng oil mo yung impurities and carbon sa loob ng makina mo.
    it might be too early since your using a semi syn oil,but still dapat nagingitim nga yan kahit konte.
    Mar 2003
    sakin kalalagay pa lang ng langis pagka start umi-itim na agad.
    Aug 2005
    kaya pala eh.. semi synthetic iyan sir. its too early to change . nangigitim yan kpag 6k+ na.
    My semi synthetic delo sports still not putik in 6k.
    its still ok dont worry about it.
    thanks!
    kala ko kasi pag diesel kailangan 4k palang palit na oil
    semi-synthetic pala eh! kung mineral based yan pag start pa lang darker na agad.
ano mas maganda oil....
